Old 03-27-2024, 01:33 PM
Brettster Brettster is offline
Default Keyboard Maestro functionality is broken with PT 2024
The new PT has seemingly broken the ability for Keyboard Maestro (and I'm assuming other similar software) from executing sub-menu commands. This really sucks for my workflow.
For instance, the Delete Fades command is technically the sub menu "Delete" under the menu item "Fades". I've used this with KM for years but now it doesn't work.
Is this a known issue? Any fixes? I seem to remember this being listed as an issue before PT was approved for Sonoma. But now that it is, I expected this bug to be worked out.
And yes, I'm using Sonoma.
Old 03-27-2024, 01:44 PM
BScout BScout is offline
Default Re: Keyboard Maestro functionality is broken with PT 2024
This is macOS getting in the way.
Go to Privacy & Security > Accessibility. Remove Pro Tools and KM (the minus key at the bottom, not just turning the toggle switch), then hit the plus and add both back making sure the toggle switch is on.
(If you use Eucon/Eucontrol, also do the same for EuControl and MC_Client)
Then reboot the computer.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 03-27-2024, 05:43 PM
1m1 1m1 is offline
Thank you for this! I've been creating work arounds for this issue, but in my early testing this fixes the issue.
In your experience, once you have it working, does the solution stick and not recur?
Old 03-27-2024, 09:57 PM
The solution works but depends on Apple. I've noticed (since late last year) that any macOS updates will break this (like a macOS 14.4 upgrading to macOS 14.4.1)
So be prepared to do this again if you apply a system update (you should have automatic system updates turned off! That way you'll know when you do them, if anything.)
But the fix is good in any other circumstances (it's not going to stop working out of the blue.)
Old 03-27-2024, 10:55 PM
1m1 1m1 is offline
That's great to know... thank you!
Old 03-28-2024, 10:00 AM
Eric Lambert's Avatar
This is interesting. What behavior in EuCon does this fix? It seems that everyone in my company is having issues of some sort, unexplained so far.
Old 03-28-2024, 10:13 AM
Key commands. Anything in Eucon that uses a keyboard command (vs a Euconzied command)
MC Client makes keyboard commands (like Cmd+shift+R) sent from Eucontrol appear to the system like it is coming from a keyboard when allowed in Privacy & Security > Accessibility. (other programs do this too like Logitech Options to make mouse buttons send keyboard commands)
The problem is the toggle switch shows "allowed" for the programs (when they are installed and ask for to be allowed) but after one of these macOS updates, it appears those settings are being overwritten by the system. Removing and re-adding the program re-writes "allowing" the application.
For some reason, Eucontrol/MC Client are the main programs I've seen having this problem (Logitech and Wacom, for instance, still persist in working after macOS updates.) But KM seems to be another.
Old 03-28-2024, 02:17 PM
dang this isn't working for me
Old 03-28-2024, 02:53 PM
Sorry, just noticed you are using Apple's system-wide keyboard shortcut system. That's the not same as keyboard shortcut keys.
My guess is a conflict between Apple's keyboard shortcut system and Pro Tools in-built. Or it isn't allocated anymore. In Pro Tools, when you go to that drop down menu, do you see the assigned keyboard command to the right? And if you do, if you press the keys on your keyboard, does it work?
A better goal is to not use Apple's system and use only Pro Tools' system for the future.
Old 03-28-2024, 03:35 PM
There is no in-built shortcut for the "Delete" sub function under the Fades menu. That's what I've been using Keyboard Maestro for and would prefer to keep it that way.
Keyboard Maestro - how's it help you? bolooki Pro Tools 2019 6 04-18-2020 02:07 AM
Keyboard Maestro Help TrentWilliams Tips & Tricks 1 12-08-2015 11:13 AM
Keyboard Maestro Trouble TrentWilliams General Discussion 0 12-08-2015 03:40 AM
Keyboard Maestro and PT 11 blankpro General Discussion 0 12-18-2014 08:20 AM
Quickeys or Keyboard Maestro or ? BMann Tips & Tricks 7 08-26-2010 08:17 PM
