Old 03-26-2024, 07:14 PM
skylar_battles skylar_battles is offline
Default Behavior Change for Interleaved Bounces
I noticed this a few versions ago. Now, if you select multiple sources and do an interleaved bounce, if some of the material was mono, you will get a mono file for the appropriate material. This is honestly preferred for me, so I can bounce mono and stereo tracks/AUXs at the same time, but wasn't sure if this was documented or causing anyone issues.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 03-26-2024, 09:50 PM
tope d's Avatar
tope d tope d is offline
Default Re: Behavior Change for Interleaved Bounces
Hi, can you post your Bounce Settings for reference?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-26-2024, 10:29 PM
Attached! Thanks!
MacBook Pro 16"
1TB SSD storage
Ventura 13.6.4
Old 03-26-2024, 10:54 PM
its2loud its2loud is offline
This is the track bounce window, not a session bounce.
Old 03-27-2024, 05:49 AM
tope d's Avatar
Should be as expected. Wanted to try it on PT 9 and see but I dont have an older system with me :)
-Tope
www.topedomingo.com
Old 03-27-2024, 07:26 AM
smurfyou smurfyou is offline
That's how it's supposed to work.
~Will
Old 03-27-2024, 08:36 PM
I'm happily wrong then! I tested with Track Bounce and Bounce Mix and it behaves the same way.
Oddly though, today when doing Track Bounce or Bounce Mix, the resulting files don't specify the width in Finder. I bounced stuff out yesterday and it definitely specified the file width in Finder. Any ideas why this might be happening? Thanks.
MacBook Pro 16"
1TB SSD storage
Ventura 13.6.4
change Default bounce format to interleaved gdgross Pro Tools 2019 13 03-22-2020 01:21 PM
weird interleaved behavior in 11HD bcslaam Pro Tools HDX & HD Native Systems (Win) 1 08-29-2013 10:36 PM
Speed change when dropping interleaved file on track Steve Canuck Pro Tools TDM Systems (Mac) 2 07-30-2010 08:35 AM
another 7.4 change of behavior sophie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-21-2007 11:49 PM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
