Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
  #21
Old 03-26-2024, 09:39 AM
EddieJones's Avatar
Default Re: EuCon Error starting up MC_client at 23.11 version.
Originally Posted by cca102 View Post
+add
I add my PT app(24.3) but it isn't not working.
Just error...
Pro Tools is EUCON. This is for Mackie Control DAW's. Remove it as it will confuse the issue.
Is there any point that EuControl actually runs, or does it always throw that error?
  #22
Old 03-26-2024, 03:39 PM
cca102 cca102 is offline
ah, okay, I remove it.
I remove PT but always throw same error...
  #23
Old 03-26-2024, 03:45 PM
EddieJones's Avatar
And you are 100% sure you did this? and then only installed the top option after a reboot.
  #24
Old 03-26-2024, 05:03 PM
Yes, I select that option, reboot, reinstall and reboot. but I reboot and Run EuControl, The same error occurred.
  #25
Old 03-26-2024, 05:38 PM
EddieJones's Avatar
Can you copy everything from this folder and zip it up. Send me a link to where they are. C:\Users\$Yourusername$\AppData\Local\Avid\Logs\Eu Con
  #26
Old 03-27-2024, 03:34 AM
I found it. I zip it up and send you link by private message. check it.
  #27
Old 03-27-2024, 10:42 AM
EddieJones's Avatar
The logs show it trying to pick a different network adapter. Do you have any others enabled? Wifi? VPN ? If not try this.
Uninstall EUCON again as before. Then from Windows uninstall Bonjour. Then reboot and install EuControl again (which will instal the correct version of Bonjour)
  #28
Old 03-27-2024, 04:43 PM
okay, I cut off other networks. (It's a vpn and usb lan port)
I did it the way you suggested, but the same error occurs.
error log is this
======== HSL logging started at Thu Mar 28 08:35:59 2024 ========
HSL enabled logging of category 3 (via internal HSL default)
HSL enabled logging of category 4 (via internal HSL default)
HSL enabled logging of category 5 (via internal HSL default)
HSL enabled logging of category 6 (via internal HSL default)
HSL enabled logging of category 160 (via MC_Client init)
1 08:35:59.839833 (0000.000000) INFO [Main ] Starting MC_Client
2 08:35:59.903709 (0000.063875) INFO [Main ] Crashpad error reporting enabled
3 08:35:59.904239 (0000.000530) INFO [Main ] OS: Windows 10 10.0.19041.3636
4 08:35:59.904243 (0000.000004) INFO [Main ] App Architecture: Intel 64-bit
5 08:35:59.948705 (0000.044461) INFO [Main ] [[SCN1]] SERVERMODULE 00000000004C2258 BEING CREATED, NEW TOTAL: 1
6 08:35:59.948836 (0000.000131) INFO [Main ] [[SCN1]] SERVERMODULE 00000000004C26A0 BEING CREATED, NEW TOTAL: 2
7 08:35:59.952128 (0000.003291) INFO [Main ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\bonjorb.cpp:358 BonjORB interface reset to use ANY interface index and Local Loopback IP Address
8 08:35:59.952148 (0000.000020) INFO [Main ] Running MC Client...
9 08:35:59.954905 (0000.002757) ERROR [Thread 0x4048 ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\eudofdnsservices.cpp:94 DNS Services error: Bad Parameter
10 08:35:59.954910 (0000.000005) ERROR [Thread 0x4048 ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\bonjour \source\eudnsservices.cpp:1420 RemoveServiceRef - null ref pointer, or parent service
11 08:35:59.956984 (0000.002074) ERROR [Thread 0x4048 ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\eudofdnsservices.cpp:90 DNS Services error: Bad Parameter, msg: error in registerServiceWithBonjour:{EuNetService - this:00000000004EDED0, domain:, type:_EuDOF-._tcp., name:EUCON_Workstation AE-A9-EF-B4-00-00, hostName:, NIC:0}
12 08:35:59.956988 (0000.000004) ERROR [Thread 0x4048 ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\bonjour \source\eudnsservices.cpp:1420 RemoveServiceRef - null ref pointer, or parent service
13 08:36:09.958507 (0010.001518) ERROR [Main ] Timeout waiting for MCClient to go online
14 08:36:41.226851 (0031.268343) ERROR [Main ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\euservermodule.cpp:314 ServerModule safety barrier timeout
15 08:36:41.226877 (0000.000025) INFO [Main ] [[SDEL]] SERVERMODULE 00000000004C26A0 BEING DELETED, new total: 1
16 08:36:41.226892 (0000.000015) INFO [Main ] [[CGRA]] CONNECTIONGROUP 00000000004C2740 (SrvMod) REMOVED ALL CONNECTIONS, new total: 0, ready count: 0
17 08:36:41.226895 (0000.000003) INFO [Main ] [[SDEL]] SERVERMODULE 00000000004C2258 BEING DELETED, new total: 0
18 08:36:44.227511 (0003.000615) ERROR [Main ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\euservermodule.cpp:359 StopReceiving: timeout waiting for thread exit. this=00000000004C2258, state=SHUTDOWN, before setting state to SHUTDOWN state was:STARTUP
19 08:36:44.227543 (0000.000032) INFO [Main ] [[CGRA]] CONNECTIONGROUP 00000000004C22F8 (SrvMod) REMOVED ALL CONNECTIONS, new total: 0, ready count: 0
20 08:36:44.227557 (0000.000013) INFO [Main ] [[CGRA]] CONNECTIONGROUP 00000000004C22F8 (SrvMod) REMOVED ALL CONNECTIONS, new total: 0, ready count: 0
21 08:36:44.227563 (0000.000005) INFO [Main ] MC_Client exiting
  #29
Old 03-27-2024, 06:11 PM
EddieJones's Avatar
This is MCClient, the log I need is EuControl. Did you do the uninstall of Bonjour?
  #30
Old 03-27-2024, 06:17 PM
Yes, I uninstall Bonjour.
And this log is same log from
"C:\Users\$Yourusername$\AppData\Local\Avid\Logs\E uCon"
maybe I need other logs, now I away from the PC so I can send log to you in the early morning
MC_client error on eucon 23.11 version. cca102 Avid S1, S3, Dock and Control App 0 03-16-2024 05:03 AM
New version of EuControl & MC_Client dominicperry Pro Tools 5 02-11-2022 08:49 AM
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
"incompatible EuCon version" error when launching Logic X MowingDevil Artist Series 6 12-01-2017 08:51 AM
