Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-22-2024, 08:28 AM
cca102 cca102 is offline
Default Re: EuCon Error starting up MC_client at 23.11 version.
Yes, I confirm Uninstalled using the installer.
I use Ethernet, connect on Wifi louter.
Old 03-22-2024, 08:30 AM
EddieJones's Avatar
Can you go to a cmd window and type ipconfig and show me the results?
Old 03-22-2024, 08:36 AM
here.
이더넷 means Ethernet on korean.
Old 03-24-2024, 06:17 PM
EddieJones's Avatar
That was it, nothing else from that command. Can you try ipconfig /all
Old 03-25-2024, 12:37 AM
oh, okay.
The host name is my real name, so I covered it.
  #16
Old 03-25-2024, 09:27 AM
EddieJones's Avatar
I dont see much wrong, expect those DNS server addresses seem strange...These are usually on the internet not local addresses.
  #17
Old 03-25-2024, 04:43 PM
I am using the DNS server of KT, a Korean carrier.
KT
kns.kornet.net 168.126.63.1
kns2.kornet.net 168.126.63.2
Should I change the DNS server?
  #18
Old 03-25-2024, 05:06 PM
EddieJones's Avatar
Can you go to the old Windows Control Panel and screen grab the EUCON settings in it. Whats the network set to and is External Workstations selected (should be off).
  #19
Old 03-26-2024, 01:12 AM
Network Interface select Use all interfaces...
and External Workstations off.
I change network interface
  #20
Old 03-26-2024, 09:14 AM
+add
I add my PT app(24.3) but it isn't not working.
Just error...
MC_client error on eucon 23.11 version. cca102 Avid S1, S3, Dock and Control App 0 03-16-2024 05:03 AM
New version of EuControl & MC_Client dominicperry Pro Tools 5 02-11-2022 08:49 AM
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
"incompatible EuCon version" error when launching Logic X MowingDevil Artist Series 6 12-01-2017 08:51 AM
