Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-16-2024, 08:09 AM
cca102 cca102 is offline
Default EuCon Error starting up MC_client at 23.11 version.
I install eucon 23.11 version.
But I can't run eucon with
EuCon client monitoring service detected a problem and will now exit.
Please check your network settings and connections
Error starting up MC_Client
So I searched for a solution and found it.
Avid Knowledge Base
MC_Client detected a network problem, Bad or Null CORBA POA
However, EuConStart also does not exist in the installation path, and you will get an error when you try it that way.
How can I solve this problem?
I use window 10, AMD Ryzen 7 3900X.
Old 03-18-2024, 11:29 AM
EddieJones's Avatar
Default Re: EuCon Error starting up MC_client at 23.11 version.
Look for EuControl Icon in the bottom right corner notification icons. Right click to find the autostart option.
Old 03-19-2024, 02:14 AM
I can't find any option buttons. It has about and exit.
And error message is it.
Old 03-19-2024, 08:10 AM
EddieJones's Avatar
Right click on the EuControl Icon not MCClient
Old 03-19-2024, 06:10 PM
I can't find EuControl Icon, I can find only MCclient...when I start EuControl, Only the MCclient error pop-up window appears...So I can't Right click on EuControl Icon...
Old 03-19-2024, 07:13 PM
EddieJones's Avatar
That either means it hidden..click the little up arrow. Or its not started, in which case quit MCClient and start EuControl. If this still doesn't help run the installer again and select remove all apps and remove all prefs. Reboot and reinstall EuControl.
Old 03-20-2024, 02:18 AM
I Check little up arrow. But I can find only MC Client icon. well...I tried reinstall EuControl many times...But I can't find EuControl Icon. I'm so frustrated...
Old 03-20-2024, 09:04 AM
EddieJones's Avatar
Did you follow the uninstall via the installer method? If the Icon is not there the EuControl is not running. If you go to start and search for EuControl and run it what happens?
Old 03-20-2024, 04:53 PM
I use installer.
And When I start EuControl and wait just minute...
This error window appears.
And I check background process EuControl but I can't find icon.
I retry open Eucontrol but I can't open it.
Old 03-22-2024, 08:20 AM
EddieJones's Avatar
To confirm you uninstalled using the install?
What Network adapters do you have enabled? Ethernet, Wifi?
MC_client error on eucon 23.11 version. cca102 Avid S1, S3, Dock and Control App 0 03-16-2024 05:03 AM
New version of EuControl & MC_Client dominicperry Pro Tools 5 02-11-2022 08:49 AM
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
"incompatible EuCon version" error when launching Logic X MowingDevil Artist Series 6 12-01-2017 08:51 AM
