Old 03-09-2024, 03:15 AM
Kaneepa Kaneepa is offline
Default Missing AAX Plugins.. 2024.3 problem.
Opening older sessions in Native mode pt 2024.3 randomly opens a dialog box with "MISSING AAX Plugins : The following plugins were made inactive because they are either missing from the plugins folder or are not a universal binary and requires Pro Tools to be opened with Rosetta" message..
Opening the same session every time gives a different list of plugins.
Btw, all the plugins installed are AAX Silicon Native, and perfectly working with 2023.12.1 in Native mode.
If I switch 2024.3 to Rosetta, the session opens fine.
Here's a dropbox link to the dialog box
https://www.dropbox.com/scl/fi/anz7m...flgumkb2e&dl=0
Anyone ?
Old 03-09-2024, 03:40 AM
Default Re: Missing AAX Plugins.. 2024.3 problem.
Quick update, reloading the session the plugin list is different.
Here's a link.
https://www.dropbox.com/scl/fi/v7xq0...akgjdab94&dl=0
Rebooting my Mac Studio M2 Ultra and reloading the same session didn't give any error about Missing AAX Plugins. Very weird.
Old 03-09-2024, 09:38 AM
Default SOLVED Re: Missing AAX Plugins.. 2024.3 problem.
Found a solution..
Deleted all the plugin .cache files created inside users/shared/pro tools/AAXPluginCache and let ProTools re-scan all your plugins.
No more problems loading older sessions.
Old 03-21-2024, 05:34 PM
Actually the problem is still happening randomly everyday.
I get the message about the missing plugins. I quit Pro tools, and reopen it and 90% of the times the session finds all the plugins and works normally.
Please help!
Old 03-21-2024, 07:34 PM
basslik's Avatar
basslik basslik is offline
Man that's gotta be frustrating.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 03-22-2024, 01:37 AM
Anyone ?
Old 03-25-2024, 07:33 PM
lee52813 lee52813 is offline
It does happen often that plugins randomly fail or some missing when opening protools project or you insert s new plugin. You're not really sure which plugin will fail every time. Seems that starting with this version of 2024.3, Protools uses a new mechanism for plugin scanning, as the AAX plugin info file inside the user library's preference is no longer relevant.
Old 03-26-2024, 11:43 AM
MLaudio MLaudio is offline
I am experiencing the same thing with an Arturia plugin. I have been working with them to try and figure out whats going on. Nothing has worked so far. Ill report back if we discover something.
Old 03-27-2024, 04:33 PM
faraway faraway is offline
I am noticing a similar issue intel mac also. Plugins will not load without any warning but will load sometimes when PT is restarted. Also when I delete the AAX plugin cache and load PT, the pluginrunner process will crash several times during the scan process.
[FS] $350 [104 Waves Plugins] SSL CLA API Puig Tape DIAMOND Vinyl OMNI Abbey WUP 2024 Electronic1982 Buy & Sell 2 12-05-2023 02:35 PM
[FS] $299 [28 Waves Plugins] SSL CLA API Puig Tape Vinyl OMNI Abbey Kramer WUP 2024 Electronic1982 Buy & Sell 0 11-26-2023 01:58 PM
Plugins missing in Pro Tools Plugins folder geniema Licensing & Accounts 14 04-22-2023 03:52 AM
missing plugins - missing subscription pt12 jazztronauts Pro Tools 12 0 02-23-2016 09:38 AM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 10:27 AM
