Old 09-27-2023, 07:45 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Default Re: MacOS Sonoma
I'm having issues with Sonoma. Audio dropouts galore.
There's a new microphone icon in the menubar. It blinks off/on with the dropouts. Same issue when running Logic Pro. It may be Soundsource related? I thought it might be related to Logitech options (which I uninstalled). Any other ideas?
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
Old 09-27-2023, 08:14 AM
Given the CoreAudio changes... interface and driver version? What happens when you test with the built in output? What does the interface vendor/community say about running in Sonoma?
Old 09-27-2023, 08:30 AM
JFreak's Avatar
JFreak JFreak is offline
I did the in-situ upgrade for updating libraries and just testing it out. So far so good. Time for a clean install when they release dot-one.
Janne
Old 09-27-2023, 08:43 AM
BCnSTL's Avatar
The dropouts occur during recording and/or input monitoring. Haven't tried with the built-in audio. I will.
PT 2024.3 Native
Old 09-27-2023, 05:41 PM
off the wall's Avatar
off the wall off the wall is offline
I've got Pro Tools running on my test MBP 14" M1 Pro, Sonoma 14.0. No extensive testing but PT 2023.9 boots, loads all my normal plugins, and plays audio out the MBP speakers. So at the very least - NOT a disaster. That's as far as I had time to look at tonight.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #16
Old 09-27-2023, 05:54 PM
Fishbone Fishbone is offline
Installed Sonoma update in a separate SSD in which I've a copy of my Ventura working system.
Launched a large session with a lot of 3 party plugins to test things out, and although it played fine with no audio related problems, the graphic performance was terrible, with meters becoming sluggish as hell as well as plugin interfaces.
It seems this problem arises with large sessions with a lot of plugins, since I've tested it with a small session and wasn't that bad, although I could tell there was a worst graphic performance comparing to the same session running in my Ventura System.
Both systems were running the latest PT 2023.9 in Apple Silicon mode.
MacMini M1 16Gb - MacOS 13.6.4 - 14.4 - Pro Tools 2024.3 - UAD Apollo Silver 8+16 - UAD Satellite octo - SSL UF8+UC1 - Softube Console 1 + Fader
  #17
Old 09-28-2023, 04:08 AM
OpiZA OpiZA is offline
I can confirm this observation. And a few others.
Back on Ventura, buttery.
As expected, but nice to see for oneself
  #18
Old 09-28-2023, 08:37 AM
BCnSTL's Avatar
Just discovered (told, actually, by Gruv over on gearspace.com) that this is the Contuinity Camera feature on the iPhone. I turned it off. Problem gone.
I am grateful for the helpful people on these forums.
PT 2024.3 Native
  #19
Old 09-28-2023, 10:45 AM
gnjlee gnjlee is offline
Excellent info. Thank you for sharing.
  #20
Old 09-29-2023, 02:32 AM
TLK Tom TLK Tom is offline
Observations:
Plugin search is now broken, you have to click 'search' instead of just typing. Really annoying for workflow, also all custom shortcuts assigned from the keyboard pane in system prefs no longer work unless the menu they are accessing is already dropped down. Not sure if the two are related?
Other than that - Pro Tools takes a little longer to load sessions now, but once loaded it's really smooth. System notifications no longer seem to stop playback when popping up, which was my biggest reason to move up to Sonoma.
Also, Sonnox inflator crashed Pro Tools the first time I opened it, but weirdly seems ok now...
Tom
macOS 12.4? off the wall macOS 36 06-06-2022 11:50 AM
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur newstrings Pro Tools HDX & HD Native Systems (Mac) 6 01-15-2022 11:48 PM
macOS 11.6.2? off the wall macOS 9 12-19-2021 08:46 AM
Macos big sur nesseldigital Pro Tools 2020 2 12-27-2020 04:49 PM
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
