Old 07-22-2022, 07:00 AM
Mr.X Mr.X is offline
Default Linking channel parameters
On the S6L, how does one link the parameters of several channels? (more than 2)
e.g. linking output eq's across multiple outputs?
Old 07-22-2022, 09:42 AM
emluper emluper is offline
Default Re: Linking channel parameters
Multi-Select your input channels or output busses, then make any changes that you want on one of the selected channels. All the currently selected channels or outputs will follow the changes that you just made.
Old 07-24-2022, 09:31 PM
Thank you for your reply. I know about multi select, I’m wondering about a permanent link.
Old 07-25-2022, 07:40 AM
I spent this weekend digging deep into Events to see if there was a way to trigger certain channels, outputs, using Multi-Select or other actions. I couldn't find one. If you need groups of linked channels that you can access immediately, I think it several of us need to request this as a feature.
Linking same plugin parameters Jcalla Pro Tools 2019 3 05-13-2020 09:33 AM
Linking multiple plug-in parameters while maintaining relative values raal Tips & Tricks 4 04-28-2019 02:02 PM
Linking channel mutes TheMAXX7 VENUE Live Sound Systems 9 02-11-2012 03:50 PM
Linking Plugin parameters w3ird Tips & Tricks 6 11-01-2008 08:41 AM
linking aphex stereo plug-in parameters c-post Pro Tools TDM Systems (Mac) 3 06-14-2007 09:14 AM
