Re: resetting the hardware engine
PT will use Windows ASIO as a sound output, the sound control panel has settings for bit rate etc. Just select the same way as the Steinberg. Now , Pro Tools will only open a given session in its original sample rate (44, 48,96 etc). If you wish to use a session that was started in 48 with 44 sample rate you have to open it first in 48 and than do a save as or save copy and choose conversion in the dialog box to the rate you want to use. Youll have two sessions but it will work.Consider one a backup. If you try to open a session with the wrong sample rate PT tries to close the session, change the sample rate of the chosen audio engine then reopen but if the interface or hardware engine isn't set up for the new rate it will either lock up or quit.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
I just realized maybe its only PT First that will use Windows ASIO. I don't think I ever tried with Vanilla. Worth a shot. Everything else applies I think
HD OMNI not showing up in Hardware / Playback Engine Tab. | rpmprod | Pro Tools HDX & HD Native Systems (Mac) | 3 | 01-20-2017 03:25 PM |
Upgraded Hardware/Playback Engine Issues | WeaselFlix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-21-2010 07:49 PM |
Cannot recognize Digi Hardware - resetting firewire drives? | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-04-2007 09:44 PM |
Resetting 002 Hardware | BenTerry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2004 11:54 AM |
HD hardware and playback-engine settings? | Allan Speers | Pro Tools TDM Systems (Mac) | 8 | 10-03-2002 05:47 AM |
