Old 05-04-2017, 03:26 PM
grateful grateful is offline
Default This pop up prevents me from starting Pro Tools
Hello,
Thanks in advance for any help.
I get the following pop up which I can't get past in order to open a new session:
Session must be on an audio record volume. If permitted, set the volume(s) in question to "R" (record) in the Workspace.
Thank you,
Grateful
My specs:
Pro Tools LE 8 version 8.0
Mac OSX 10.5.8 Leopard
2.53 GHZ Intel Core 2 Duo
Memory: 4GB 1067 Mhz DDR3
computer: Mac Book Pro
Old 05-04-2017, 03:42 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: This pop up prevents me from starting Pro Tools
Are you unable to change the record volume as directed here?
linkedin
Old 05-04-2017, 04:06 PM
Thanks for the response, Jeffro. I cannot get past the pop up to open a new session.
Old 05-04-2017, 04:21 PM
jeffro's Avatar
So you get this just launching the Pro Tools app? (Not launching by double-clicking a session.)
Was this working previously?
How are the drives in this system formatted?
linkedin
Old 05-04-2017, 04:25 PM
Jeffro,
I did what you said and discovered that the R checkbox will work on the computer's internal drive. I can open a session on the internal drive. I was trying to save the session to an external drive made by Other World Computing (OWC). Isn't that what I ought to do? When I tried to check the R next to the external drive I got this pop up:
OWC SETUP cannot be designated as an Audio Record volume because it is not a valid audio volume.
I'm confused. I bought this 1TB ext. drive (OWC brand) to record my audio sessions onto. What do I do now?
Last question. If this problem is fixed and I can use the OWC drive to record onto, should I also install my sound libraries on this same volume?
Thank you so much,
grateful
Old 05-04-2017, 04:30 PM
Hi Jeffro,
You posted as I was writing and I saw it after I sent my last post.
I am about to reformat the ext. drive.
Old 05-04-2017, 04:34 PM
jeffro's Avatar
If it's a new drive it might be formatted for Windows (e.g. NTFS)... check it in Disk Utility, and erase/format for Mac if needed.
As far as storing your sound libraries, factors include drive speed as well as if your VIs load samples in memory vs stream from disk. If the the latter then it might be better to have them on another drive.
Others might chime in with their experience if you can share more detail about your setup and what you want to do.
linkedin
Old 05-04-2017, 05:47 PM
It turns out that I couldn't reformat the drive and am sending it back after speaking to tech. support.
"Helper application" prompt loop prevents PT from starting jeremyseanbell Pro Tools 12 2 04-13-2016 12:29 PM
DigiReWire prevents PTLE from starting Elecshop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-13-2009 09:39 AM
Axiom 25 prevents fader banking travistko MIDI 0 03-16-2009 07:31 AM
QuickTime 7.3 update prevents Pro Tools from launching Kharmaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-07-2007 08:45 AM
Autotune prevents PT startup smilez03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2005 06:39 AM
