Mbox 3 Ground or Hum noise
Good Day. Since the last 2 days my Mbox 3 starts to give me some noise in both inputs, is not very hard but it´s damaging my recordings. In the control panel of the Mbox you can see the noise.Mbox3Hum.jpg
How can I fix it. Thank´s |
Re: Mbox 3 Ground or Hum noise
This could be any number of things. Is this happening even without any instrument or mic connected? Since it is showing on the meters, I don't think it would be ground loop related though.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Actually in the picture shows the problem without anything connected and I´ve already used another cable.
I think it might be a failed preamp. You might have to send it in for repair. Your best bet would be to use the free ASC you received when you purchased the Mbox to contact Avid:http://www.avid.com/US/support/support-contact
Joel
What's connected to those inputs? If it's anything that requires power from the wall, I would try to get it on the same outlet as your computer as this seems like you have a grounding issue.
Well I thought that the problem were the preamps, but this problem occurs with both preamp knobs closed to zero (0db), only with the faders on the Mbox control panel opened, so it is a little bit weird.
In the other hand there is nothing connected to the inputs, and i´ve already tried to connect the Mbox to another computer and happens again in PC and Mac. |
I've recently bought a brand new MBOX3 pro with protools 11. While recording via protools I am getting high frequency ground loop but if I use any other DAW the recordings are fine. Please suggest. I am running protools 11.0.2 on Windows 8.1. no instrument connected, just one dynamic microphone. MOBO: GAZ87X UD5TH CPU: Intel i7 4770K RAM: 16 GB DDR3 1600 MHz |
solving mbox ground noise | queemacarthur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 11-21-2013 12:41 AM |
Noise problem possibly ground loop with mbox mini | Kiawa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-28-2011 09:44 PM |
Noise with Mbox 2 is a GROUND LOOP... | virgult | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-29-2010 06:00 AM |
ground noise | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-10-2001 09:17 PM |
HELP! AC Noise/RFI/Ground hum | unclemurray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-08-2000 05:11 PM |
