Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-19-2014, 01:45 PM
agrizzlybear agrizzlybear is offline
Default Using a Distressor as a hardware insert with Avid Omni & ProTools 11 HDX
Hi there,
Could anyone please talk me through how to set up my EL Distressor as a hardware insert with an Avid Omni and PT 11 HDX? I've tried doing it but keep getting a horrible delay in the audio no matter what H/W delay compensation settings I use.
Would REALLY appreciate any help as I'm fairly new to this. Thanks ever so much!
Alastair
Old 03-19-2014, 01:53 PM
Craig F Craig F is offline
Default Re: Using a Distressor as a hardware insert with Avid Omni & ProTools 11 HDX
do you have it as a send and return or as a hardware insert?
you want it as an insert so input and output must be the same (out 3 / in 3)
Thank you,
Craig
Old 03-19-2014, 02:09 PM
I'm trying to use it to mix with rather than record so I'm using it as a send and return. Is that the right thing to be doing? Thanks for the super fast response!
Old 03-19-2014, 02:31 PM
No, there is no delay compensation on send and return
ADC is only on Hardware Insets
a hardware insert can be used on an Audio track, Aux track, or Master fader
you need to set it up in the Insert tab of the I/O Menu
Thank you,
Craig
Old 03-19-2014, 03:08 PM
Ok - so I've now re-wired my Distressors to go in to inserts 3 & 4 on my omni and the outputs to go out of 3 & 4, and I've re-named them in the insert tab of the I/O setup.
When I go to insert I/O as a plugin it shows me the Distressor names but says DigiLink n/a afterwards and they're inactive. How do I activate those now?
Many thanks!
Alastair
Old 03-19-2014, 06:54 PM
Do you have 3&4 assigned in Inputs and Outputs as well?
Thank you,
Craig
Old 03-20-2014, 08:44 AM
Sorted it!!! Thank you SO much! Last question - can I expect to have to manually add any hardware insert delay time for the Distressors or will they be covered by ADC?
Thank you so much again!
Alastair
Old 03-20-2014, 10:11 AM
They should be covered by ADC automatically when you have it turned on
A digital processor might need to be compensated for a hardware reverb I'd work the offset into the pre-delay
Thank you,
Craig
Old 03-20-2014, 12:10 PM
Thanks again!
PT10.3, HD2 accel Avid I/0 Hardware insert issue? mattpgtr macOS 0 10-20-2012 10:52 AM
Hardware insert with non-Avid/Digi interface? ChuckS Pro Tools 10 3 03-06-2012 06:38 PM
Support ? OMNI Hardware insert ADC question K Roche Pro Tools HDX & HD Native Systems (Mac) 4 04-02-2011 11:50 AM
OMNI ADC and Hardware insert question K Roche Pro Tools HDX & HD Native Systems (Mac) 4 03-06-2011 05:21 AM
003R + distressor, routing, tracking, insert ? suitelounge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-28-2009 06:31 AM
