Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-18-2014, 08:31 PM
def3mno62 def3mno62 is offline
Default Protools could not initialize audio driver
Whenever I try click the play button I get this message: "Protools could not initialize the Focusrite USB 2.0 audio driver. Please make sure that the device has been configured correctly." I've had this problem way in the past when I first got protools and can't remember how I fixed it. It was working perfectly fine before and just randomly I get this message :/ I tryed pressing N at the splash screen and changing it to all the different options but that either didn't change anything or I'd just get a different error message in its place so help would be appreciated
Old 03-24-2014, 03:12 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Default Re: Protools could not initialize audio driver
Hi def3mno62,
What driver version do you have installed?
If you have 2.5.1 can you try uninstalling it from Control Panel > Uninstall a program and then install 2.5b4 from here.
http://beta.focusrite.com/releases/f..._usb2_drivers/
If you need more help please contact us directly so we can assist you better and get your computer details.
http://us.focusrite.com/answerbase/contact
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 03-25-2014, 01:33 PM
holywoodj holywoodj is offline
Did you ever get this fixed? I'm having the same issue with the Focusrite Saffire 24DSP.
Old 03-27-2014, 09:25 AM
Focusrite
Hi holywoodj,
As you have a Firewire Interface and not a USB Interface they use a very different driver and thus they likely have a very different reason for you receiving a similar error message.
As this is a Firewire Device and we are not aware of any specific problem there can you please contact us directly so we can get some more specifics on your computer settings and session and assist you better?
Best Regards.
Old 03-29-2014, 02:20 PM
tross405 tross405 is offline
I've had the same problem. I feel your pain. I got PT to work the first night I installed. Since then, a month and a half later, i still haven't made one recording. As for the "could not initialize Focusrite 2.0", I did a clean uninstall of PT 11 and it got rid of that error. Now PT crashes as soon as I hit the record button. It did give me the Focusrite error once more and I relaunched and it went back to crashing. For this kind of money it should run itself. I can't get a recording with just one mic. I do know that if you don
Old 03-29-2014, 02:22 PM
If you don't install the audio hardware driver before re-installing PT it will give you that error
Old 03-29-2014, 06:54 PM
For which one are you referring that I'd have to do a reinstall the could not initialize error or the not enough cpu power error?
Old 04-03-2014, 04:15 PM
Focusrite
Hi tross405,
We are very happy to help you out with this.
Can you please contact us directly?
Anyone having trouble with getting their Focusrite gear up and running please let us know. We are glad to help you out.
Best regards
HELP I'M IN DRIVER HELL! "The application failed to initialize properly (0xc0000005). gerry c Windows 8 01-06-2014 08:22 AM
Protools could not Initialize... davie1 macOS 0 07-12-2012 08:35 AM
Pro Tools 9 wont initialize ASIO driver for Realtek HD audio device and more fireal2112 Windows 19 05-05-2011 11:16 PM
protools 8.0.4 audio driver freeze hotrod25r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-12-2010 08:21 PM
protools 8 audio driver not recognize eranf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2010 12:52 AM
