Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-07-2014, 03:21 AM
Calon Calon is offline
Default will steinberg interfaces run PT?
eg UR22 or UR44.
My mini mbox 2 has crackly/garbled sound i try to run cubase on it
(using the native driver) so if Steinberg's gear runs PT 10 or 11 that would be very useful. Is it true that PT 9 and later will run on anything?
OR alternatively will an Mbox 3 run Cubase 7.5?
i don't really want 2 boxes for 2 bits of software but its hard to find out
which box runs both.
Ofcourse it would be good if PT had some of Cubase's musical features like a chord track then i wouldn't have to bother with Cubase but that's life
Old 03-07-2014, 05:24 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: will steinberg interfaces run PT?
Can you post your full system specs?
Yes, the Steinberg devices should work fine in the full versions of Pro Tools 9 and up (not PT 9 M-Powered though).
The Mbox 3 should also work with any DAW software.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-08-2014, 02:51 AM
Originally Posted by 68Tele View Post
Yes, Pro Tools 9 or later is compatible with most 3rd party interfaces.
And it is even (not always recommended) possible to run PT on just the built in sound card of a PC or MAC.
Mbox 3 should be compatible with Cubase (but I have not checked the specs).
* You might try another USB cable on the Mbox.
* Maybe try updating the driver, or downloading a newer or older driver for the Mbox.
* You should able to adjust interface settings in Cubase. In Pro Tools you can raise/lower the buffer settings to improve interface performance.
* If no luck, you might try the Mbox 3 with Reaper.
call me a conspiracy theorist but it looks to me like steinberg have deliberately fixed cubase not to work with mini mbox 2(MM2).
the evidence?
1 cubase works fine with 2 other interfaces i have , a ten yr old terratec sound card and a zoom g3x fx pedal, neither of which make software which competes with cubase.
2 if go to the pool in cubase i can hear the audio with no glitches and also if i open an an audio clip the scrub tool works. but when i playback audio in the arranger i get sound problems - why there and not everywhere in the programme?
3 reason,ableton,mixcraft, audacity all have no problems with my MM2 so why should cubase?
4 even if i choose a generic asio driver i still get audio problems although not as bad.
does PT 10 work ok with steinberg audio interfaces? Calon Pro Tools 10 0 03-05-2014 03:27 AM
Traditional Avid interfaces vs 3rd party interfaces aftermid Pro Tools 10 9 10-24-2012 01:12 PM
Bye Bye Steinberg !!! RT Pro Tools TDM Systems (Mac) 8 12-26-2002 12:18 AM
Bye Bye Steinberg!!! RT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2002 11:20 PM
anyone using the steinberg 8 i/o.............. slr Tips & Tricks 2 03-31-2001 04:11 AM
