Re: Disappointing List of Plugins
Would also have reaper to host a ton of vi's. Rewire I think will still be utilized once 11 is released. Also have reason as a rewire client. Both of these are 64 bit already as well so would be fine w rewire.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
VSL has said an AAX version is "in the works".
Logic is 64 bit but many people still use VE Pro so they can have a template permanently loaded.
Dave Marsden UK |
I'm guessing Avid also will have to update their VI's to the AAX format ?
Hopefully with some new sounds. |
That's an interesting proposal since Avid sold off all of their VIs.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
64 bit AAX has got to be a much much bigger priority for developers than 32 bit AAX.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#16
Why doesn't someone just write a TDM to AAX 'wrapper' like FXExpansion did. If the new chips are as powerful as we're lead to believe, someone clever could write an 'emulator' plug, that would host TDM plugs and run them on the AAX chip, right?
#17
The problem is that emulators often cost several times the original processing power. I don't think it would be very efficient, unless maybe it was TDM to AAX-Native.
#18
Why not use this newly created forum to come in and be real. Instead of blowing off legitimate concern from your customers.
ZERO information on Virtual instruments other than no AAX which is big concern. AVID does not even lead by example by insuring their on line of plugins are AAX. Don't get upset with other companies not jumping on the AAX bandwagon. How can you blame them when AVID is dragging their own heals.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#19
Darryl |
#20
What I'm really waiting for is AAX format virtual instruments. It remains to be seen whether or not AAX will fix PT's virtual instrument problems. Frankly if AAX is not any better than RTAS is when it comes to handling VI's it won't matter that PT11 is 64bit. Being 64bit only helps when you're dealing with large sample libraries. But Pro Tools will freak out right now with instruments that hardly use any ram at all. The biggest ram hogs I use a lot are Omnisphere and Kontakt but they both have external ram servers that can be used.
Is there a list of plugins in PT 9 ? | Talisker | Pro Tools 9 | 6 | 11-08-2010 01:47 PM |
Plugins list help | skitt123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-11-2008 06:33 PM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 10:27 AM |
list of Pro tools TDM Plugins. | wild eyed | Pro Tools TDM Systems (Mac) | 1 | 06-15-2004 11:23 AM |
List of Plugins for PT HD | tzouras | Pro Tools TDM Systems (Win) | 0 | 03-15-2002 11:25 AM |
