Old 02-09-2012, 02:41 PM
dreamtheater777 dreamtheater777 is offline
Default Rename Region Quick Key Doesn't Work Sometimes?
I don't know if this is specifically a 10 problem, but I've been noticing recently that sometimes my "Rename Region" quick key (Command+Shift+R) doesn't work. It will work for some sessions, but then not for others. Is there some session-based preference for this that is disabling it? Anyone else had this problem?
Thanks.
Old 02-13-2012, 11:56 AM
Default Re: Rename Region Quick Key Doesn't Work Sometimes?
Nobody's had this problem? Any help?
Old 02-13-2012, 12:05 PM
Felix Rost Felix Rost is offline
Rename Region works on the Region List. If you have an active search and the selected region doesn't appear in this search, then it's also not selected and can't be processed.
command+shift+D to clear the search and reselect should do it.
http://felixrost.de
Old 08-18-2012, 07:48 AM
mikepoplawski mikepoplawski is offline
Hiya,
I have the exact same problem with protools 10, cmd shift D doesn't help. Do you figure out how to solve it?
Old 08-18-2012, 07:49 AM
Hi, do you figure out how to fix it?
Old 08-18-2012, 09:27 AM
The golfer The golfer is offline
I had this problem several times. Both "rename clip" and Double clicking on a clip weren't working work. The only way to fix it was a computer restart. Fortunately, I did not have the problem with 10.2 yet.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 09-02-2014, 10:30 AM
Mr.Mann Mr.Mann is offline
I'm still having this problem intermittently on Pro Tools 11.2.1
Rename Clip works in the clip list, but not in the edit window.
www.donmannsound.com
Old 09-03-2014, 04:11 AM
joachim's Avatar
joachim joachim is offline
Maybe check, if "auto-created" is also shown in the clip list.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 05-27-2023, 09:50 AM
EneMeneGratschik EneMeneGratschik is offline
I know it has been quite some years, but I wanted to say thank you! I had the same problem and making the auto-created clips show in the clips list solved the problem :)
Old 03-10-2024, 07:27 AM
timothybentinck timothybentinck is offline
Such a puzzler but I finally worked it out. I had searched for something in the clip list, and the search was still open. By Clearing Search, the shortcut Cmd/Shift/R worked fine again!
PT10.3.2 Can't Rename Region little78926 Windows 2 02-13-2013 01:37 PM
Rename Audio Region and File - where go? smc917 macOS 2 09-16-2011 09:54 AM
Quick Way to Rename Regions erocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2009 02:01 PM
PT8cs2 - Rename Region Short Key quits working 25ghosts Pro Tools TDM Systems (Mac) 4 04-29-2009 05:03 AM
PT 5.1 Rename Region Bug? BackToMag Pro Tools TDM Systems (Mac) 6 06-04-2001 05:20 AM
