Old 04-23-2010, 10:20 AM
nutrinoland nutrinoland is offline
Default fruity loops in pro tools question...not regular rewire question
hi..
i am very used to using the sequencer in fruity....i particularly do not like the midi sequencing in pro tools...
is there a way that i can sequence my notes in fruity and have it trigger synths in pro tools....but i do not wanna rewire pro tools in fruity..i want to rewire fruity in pro tools..
the same way i can send midi event data into pro tools from fruity...can i send piano roll data ? basically use the fruity sequencer to trigger synths/ instruments in pro tools ?
i tried opening a midi channel in protools...
a midi out channel in fruity
an instrument channel in pro tools with expand instrument in the insert
then in the input of protools midi channel set FL midi out 1 as the device
and the output as an instrument channel in protools that i inserted an instrument, expand .
i sequenced a few notes in fruity midi out channel...
it did not work...
any idea how to do it?
use fruity piano roll to trigger protools instruments...
thanks
Old 04-23-2010, 12:39 PM
Default Re: fruity loops in pro tools question...not regular rewire question
Maple Virtual MIDI Cable
Aaron Mulqueen - 001 HD Native
fruity loops using rewire in protools le for pc JWHITE777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2012 06:59 AM
Fruity Loops Question HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-19-2010 06:47 PM
protools le 6.1/digi001 and fruity loops 4 question?? vel0city89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-08-2008 03:06 PM
Fruity Loops Rewire Doesn't Bounce EyeVeeDrip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-25-2008 11:10 AM
Rewire Fruity Loops in Pro Tools - HELP J Sniper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 07-26-2006 09:35 AM
