Upgraded Hardware/Playback Engine Issues
I just installed a new motherboard/Intel Core 2 Quad Processor 2.5 GHz from a Pentium 4 single processor. I never really had much issue with playback/tracking/latency problems on the previous setup and now I am receiving a playback error stating I should adjust my buffer size in the playback engine settings. I've experimented with several setups including changing the number of RTAS Processors, Playback and H/W Buffer size and adjusted the CPU Usage limits. PT's recognizes all 4 processors. It seems odd that I'm experiencing these problems since I should have GAINED speed and performance from the upgrade. What am I missing? Are there optimal settings for the Playback Engine and are there settings I've failed to tweak since the hardware install? The old setup only bogged down when I was mixing with quite a few RTAS plugs running. Now it acts up in a new session with 1 or 2 tracks. I'm at a loss.
Thanks in advance for any tips. ~P Intel Core 2 Quad 2.5GHz 4 GB RAM Window XP Service Pack 2 (Spectral Optimized Version) Pro Tools LE 7.1 MBox 1 KRK Rokit 8 Reference Monitors MotorMix 8 Channel Control Surface |
Playback engine issues and new document | rakins | macOS | 2 | 02-26-2013 04:32 PM |
Playback Engine issues. | Michael_Knight | Windows | 4 | 01-04-2013 08:21 PM |
Playback Engine issues | rwechta | macOS | 6 | 02-10-2012 03:26 AM |
Playback Engine issues | robbierobb | Pro Tools 9 | 6 | 10-22-2011 11:11 AM |
playback engine set up issues... need help! | tingly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2007 09:07 PM |
