Old 08-20-2009, 11:05 AM
Roy Howell Roy Howell is offline
Default Apogee Rosetta200 to 002R...would appreciate advice. ..
Hi guys...
I'm trying to get a little setup going and am having trouble syncing the apogee rosetta with the 002r. Getting nothing through my monitors yet.
I currently have phono cables going from:
s/pdif IN on the 002r to s/pdif OUT on the Apogee, and
s/pdif OUT on the 002r to s/pdif IN on the Apogee.
I'm going out of the Apogee to a NAD hi-fi preamp and into Genelec 8020's.
When i bypass the apogee (002r straight to the NAD and Gens), I'm hearing it, but not when the apogee is hooked up.
The outputs in PT are set to Analog1&2,S/PDIF, by default, so I'm assuming that is correct.
What could I be overlooking?
thanks, Roy
Quadcore with PT7.3.
rh music
Old 08-20-2009, 12:12 PM
themadarchitect themadarchitect is offline
Default Re: Apogee Rosetta200 to 002R...would appreciate advice. ..
You cannot achieve a SPDIF connection with mono rca cables. You need a coax/ S/PDIF cable. It can be cheaply purchased from just about any electronics store.
In PT, you have to change the inputs on the 002 to S/PDIF to digital instead of the default analog..Happy recording!
EDIT: Almost forgot..Once you have your coax cables hooked up, go into pro tools and under the menu "Setup" go to the option "Hardware" and in the "clock source" menu select S/PDIF (note you should have the Apogee ON when you do this). The s/pdif light on the 002 should lite and you should now have the option of using the s/pdif as an input in pro tools.
Old 08-20-2009, 12:22 PM
Thanks so much......I really appreciate it.
-Roy
rh music
Old 08-20-2009, 12:32 PM
-Roy
np..now go mix the snot of out something and post it for us to enjoy
need advice on apogee 200 hookup ilulilu888 Pro Tools TDM Systems (Mac) 1 05-01-2010 02:44 PM
002R + apogee Tuur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-28-2008 11:26 AM
Advice (M-Box 2, Apogee Mini-Me) Uli Rennert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2007 04:06 PM
Buying advice . Apogee GS-DK Pro Tools TDM Systems (Mac) 0 01-19-2006 02:32 PM
Apogee Rosetta200?? SKI Pro Tools TDM Systems (Mac) 1 08-25-2004 06:05 PM
