Old 08-15-2007, 10:56 AM
JIT JIT is offline
Default BFD samples, where to put them?
Recommended to be on a seperate drive but i was just going to use my system drive for BFD, anybody else done this? Any Problems?
I do have a seperate audio drive for recording to.
Old 08-15-2007, 01:09 PM
scottedog scottedog is offline
Default Re: BFD samples, where to put them?
Hard drives are pretty cheap these days, I run mine off of a seperate drive. You'll get better/more stable performance.
Scott.
ScottedogStudios on ReverbNation
Old 08-15-2007, 01:16 PM
The FXpansion BFD FAQ has recommendations on where to install the sample data.
You have to install the BFD application to your system drive, it's recommended that you install the sample data on a separate hard drive which is not also used for recording your audio. If that's not possible, then you should install the sample data to your system drive.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
using PT8 in 24 nit with 16 bit samples converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-02-2010 11:05 PM
samples soulcactus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2007 10:01 AM
Have I been off by 164 samples all along? scottevl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 55 01-18-2004 05:26 PM
OT - Help with Samples roxy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-04-2003 02:33 PM
samples SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-09-2000 03:12 PM
