Old 08-14-2007, 10:50 AM
JIT JIT is offline
Default Connect a pre-amp to M-Box 2?
Could i connect a pre-amp to my M-Box 2?
Thinking about a Focusrite Voicemaster, can i bypass the M-Box 2 pres?
Old 08-14-2007, 01:05 PM
6969 6969 is offline
Default Re: Connect a pre-amp to M-Box 2?
The pre-amp has to have a S/PDIF output in order to bypass the Digi pres and converters. The Mbox does have a S/PDIF input that makes this possible. I have always fantasized about the Apogee Mini-Me.
6969
Old 08-14-2007, 04:54 PM
If you don't use want to have the signal converted to digital first, you can also connect the mic preamp's analog outputs to the Mbox 2's "line in" inputs. These inputs do not have mic preamps so you effectively bypass any the M-Box 2's mic preamps.
Obsidian Dragon
Mac Studio M1Max - 64GB
How can I Connect 3 192 I/O's in HD|1? egghead Pro Tools TDM Systems (Mac) 4 11-02-2011 07:54 AM
FW 400 to 800 connect! ktwalker76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-13-2011 01:41 AM
Best way to connect 002 Cpu and HD oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-15-2008 12:50 AM
HD3 - How does it all connect?? Gallellao Pro Tools TDM Systems (Mac) 5 04-19-2008 02:23 AM
How to connect a sub to 001 Doug Paluch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-01-2003 09:54 AM
