Old 01-24-2007, 06:36 PM
rastro2 rastro2 is offline
Default Automation Problem
Hi
For some reason, PT is not recording my automation, or at least some automation moves. It happens either in Touch mode or Latch mode. I'm using a Tascam FW-184, but it happens when I'm using the mouse also. Basically, it's not reading mutes, and some plug-in automations (bypass, delay time etc.). It works fine if I go to the edit window and draw in the automation. Also, volume automation works OK, so it's kind of weird. Is this is a bug? Is there something I'm doing wrong? Help! Drawing in the automation is such a time-waster.
I'm running PT LE 7.1 on Mac Dual 2.5 gHz G5 running OS 10.4.8 with the 002 Rack.
Thanks!
Joe
Old 01-24-2007, 09:55 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Automation Problem
What happens when you unplug the Tascam FW-184? Will the mouse work then?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Automation problem seolwoo Pro Tools TDM Systems (Mac) 5 06-10-2008 09:09 PM
Anyone Had This Automation Problem? tomhartman Pro Tools TDM Systems (Mac) 1 04-06-2007 07:54 AM
Automation problem jaketanner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2006 06:10 PM
Automation Problem March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2005 10:55 AM
Automation problem Jeff Zubeck Pro Tools TDM Systems (Mac) 2 01-02-2002 04:43 PM
