Old 08-16-2006, 02:11 PM
pakobo7 pakobo7 is offline
Default Fixing Clipping in Master in Master Fader
Hey there!
If the only meter that's clipping out is my master fader, is turning down the master fader the best solution? I'm afraid of doing two things when trying to fix these clip outs...
1. I'm afraid if I turn down the master fader too far that my overall volume will be too low. I'm already at -6.0 on the master fader track.
2. I'm afraid of creating an unnatural sound if I adjust the track volume in certain places. Any suggestions?
Old 08-16-2006, 04:36 PM
sykobilly65 sykobilly65 is offline
Default Re: Fixing Clipping in Master in Master Fader
hey, you'll have to turn down your other tracks because they're feeding your master fader or 2)you can apply a limiter on your master fader & set the output ceiling to about -0.3 to -0.6 db, then if you want it louder you can adjust the threshold on the limiter. i think there's a free master limiter plugin out there and i think it's on roger nichols website. spkguitar has a link to it on his page as well. but never adjust your master fader leave it at -0.0.... i hope this helps ya out.
Old 09-12-2006, 05:24 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Hey there!
If the only meter that's clipping out is my master fader, is turning down the master fader the best solution? ...
YES! 32 bit float mixing has hundreds of dB of headroom.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 09-13-2006, 04:10 AM
Ben Jenssen's Avatar
No. This can be true in an analogue environment, but in PT you can safely rely on the master fader to control your overall volume.
No. The master fader is there to be used.
But try a limiter/compressor as suggested to retain volume on your material.
Beware: master faders in PT differ in a BIG way from other types of faders: plugins on master fader are POST fader. That means manipulating it might influence the behaviour of its plugins. The main idea behind this I think is that if you want to bounce to a file with a different bit-depth (24-16bits) you will want to use dithering, and that should always be the last thing to happen to the 0s and 1s before the file is written to disk.
Old 09-13-2006, 07:25 AM
Master faders also allow you to keep hot bus levels from clipping plug-ins.
Interview
Old 09-15-2006, 02:32 AM
finnburger finnburger is offline
So is it the best way to route all tracks to a aux bus first and put the mastering limiter there? Or just put it in the first insert of the master fader? Any difference on sound?
Old 09-15-2006, 03:26 AM
Most often I bus everything to an aux when mixing, yes. But I use that for mix bus compression, coloration and EQ if I want it, and have the master fader free for adjusting listening volume, whithout it influencing the compressor. Then if I want to bounce I can put a brickwall limiter on the master fader, plus dither, and use the aux fader for volume automation and fade outs, again without the compression being affected because aux plugins are pre fader.
Difference in sound? It´s all ones and zeros.
Old 09-15-2006, 05:22 AM
HotRats_Reloded HotRats_Reloded is offline
The best way to avoid clipping is to control your levels (tracks, busses, plug-ins) while you're mixing.
Take care of level and you'll get a mix with no clipping at all on your master fader
at unity gain.
It's also a good idea to leave some (or more) headroom while tracking.
Old 09-15-2006, 10:04 PM
dogselur dogselur is offline
Massey Plugins has a great free limiter plugin that can be upgraded. Check it out. at www.masseyplugins.com
Old 09-16-2006, 09:38 AM
Jagg76 Jagg76 is offline
What approach would you take with aux tracks clipping? (reverb, delay, etc...)
Master Fader clipping Von_Dingle Pro Tools 9 4 10-24-2011 11:47 AM
Master Fader is Clipping, what now? Peulock Pro Tools TDM Systems (Mac) 21 03-08-2009 07:06 AM
Master Fader Clipping 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-12-2006 01:44 PM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
Master fader clipping? brasssail Pro Tools TDM Systems (Mac) 4 03-15-2000 09:40 AM
