Old 06-16-2006, 08:47 AM
rock15478 rock15478 is offline
Default Adjusting volume after automation is written
Hi, I've been wondering this for quite some time now...I'm not even sure if it's possible. Let's say in the middle of mixing a song, I want to fade the guitars down at a certain point, and then fade them back up. I'd normally do this with volume automation. However, let's say a week later I want to change the overall volume of that track, but keep the automation. Is this possible? Whenever I try to change the volume on a track where automation is written, it slides the fader back to its original position. I guess I'm wondering if there's a way to proportionaly keep the automation in relation to the volume changes. Any help would be greatly appreciated. Thanks
Old 06-16-2006, 08:55 AM
RadioMoo RadioMoo is offline
Default Re: Adjusting volume after automation is written
OK, select the track you want to do this to, then hit Control+hyphen, which will put that track in Volume view. Then hit F6, the Trimmer tool, put the Trimmer tool on the Volume line, click-hold the line and drag it down; the whole line will drag down, but the automation you wrote will still be there.
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM
Old 06-16-2006, 11:42 AM
Slim Shady Slim Shady is offline
RadioMoo's suggestion definitely will work - if you don't want to mess with the automation though, you have a couple of options. If you have any sort of plug-in on that track, most plug-ins contain an input and output volume, you can just bump one of those up or down to get an overall level change on a track w/o changing the automation. You can also use the Digi 'trim' plug-in to add or subtract a little gain from any track.
Old 09-02-2015, 05:42 AM
aylavid aylavid is offline
Great tip! Do you have any good idea for PT11 for same thing? Because this does not work for PT11.
Appreciate your help,
Specifications:
Mac OSX 10.10.4
CPU: 2.8GHz Intel Core i7
RAM: 16GB 1600 MHz DDR3
Pro Tools 11.3.1
Appreciate the Rescue from Experts,
A.Y.L
Adjusting automation volume by 1dB in PT 10 cristol2k Pro Tools 10 10 01-17-2018 04:04 PM
extra automation written viaspiaggia Post - Surround - Video 4 06-14-2013 11:28 AM
Automation Being Written on Untouched Track Chief Technician ProControl, Control|24, Command|8 12 06-06-2007 11:34 AM
adjusting volume automation euphjazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-29-2005 07:40 PM
"No automation could be written.... dkroger ICON & C|24 4 12-19-2005 07:43 AM
