Old 02-17-2006, 06:16 PM
stealth_162 stealth_162 is offline
Default Losing USB Connection
Brand new Command 8. Actually this is the second one I got. I've had the same problem with both. Everytime I launch Pro Tools this happens.
While loading the session the USB connection to the command 8 is lost. I can see the USB light go out on the control surface. Once the session is open a message pops up saying that the connection to the command 8 has been lost. If I cycle the power on the command 8 once the session open it will re-connect and maintain the connection reliably.
I've tried both usb ports on the computer, also tried pluging it into a powered usb hub.
Apple G4 1.25Ghz Dual
2 Gigs RAM
HD 2
(3) 192's
(1) Sync I/O
Any suggestions?
Old 02-21-2006, 11:39 AM
Default Re: Losing USB Connection
Still Looking for suggestions/help.
Old 02-27-2006, 06:48 AM
Ray Lyon Ray Lyon is offline
Which brand of USB powered hub? Some brands are not reliable with PT. Griffin is a brand found to be reliable. (I use the 4 port model UH124Z) Also, I have found that static electricity can be a culprit with losing communication to C|8... during the dry winter months this has been a bit of a problem.
Hope this is of some service to you,
Old 03-02-2006, 09:56 PM
I'm using the I/O Gear four port hub. However. I've tried to use the CI8 without the hub connected and still had the same problem. The static thing I'm not sure about. However it consistently loses the connection when a new session is opened. Once the session is open I re-seat the usb connection and it is fine then on until I open up my next new session.
Losing TDM connection on tracks Boe Larsen Pro Tools TDM Systems (Mac) 8 07-11-2011 04:21 AM
Keep losing firewire connection Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-20-2009 11:21 AM
Keep losing connection with my 002! chanlon25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2006 04:21 PM
digi keeps losing connection rockstah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-06-2004 01:40 AM
My 002 keeps losing the connection partytrain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2004 01:03 AM
