midi not recording or playing back
Hello,
I haven't looked for hours and hours but I didn't see a problem like mine already posted so hopefully there's a simple solution. Using instrument plug ins (Sample Tank 2 se or BFD-lite), I can play and hear sounds using my midicontroller when the midi track is record enabled or when recording but most of the time the notes that are played when recording don't appear on the track. Sometimes, when all of the notes are on the track, during playback the notes play on top of eachother. Also, sometimes, the first note would play on the track, but the other notes after it are ignored. Other times, after recording, just one long, random note will sound for the duration playback. In Midi Studio Setup, only "1" is selected for both the send and receive channels like in the method one dvd. The input port is digidesign digi 002 port 1 and the output port is set at none. With a stereo aux track, one of the instrument plug ins is selected. On the midi track, the midicontroller is selected for the input on channel 1 and the plug in is selected for the output on channel 1. I have a Studiologic SL-990 PRO midicontroller with one midi out connector and no other midi connectors. I have the same problem with the controller plugged into the digi 002 midi in port or with a m-audio midisport uno connected to my pc. I've unstalled and reinstalled protools with no change. Help! Thanks, Mizziti PT7LE digi 002 WIN XP PRO SP2 Asus A8N-E AMD64 X2 +3800 2GB DDR-SDRAM PC3200 DDR 400MHz Dual Channel audio drive: Seagate Barracuda ST380021A 80GB Hard Drive (EIDE ATA-100, 7200 RPM, 8MB) |
Re: midi not recording or playing back
I spoke with tech support. I found out that the problem could be that I don't have the supported firewire card. I'll be getting it next week.
M-Powered 7.3 not recording/playing back, Please help!! | nsanc | Pro Tools M-Powered (Win) | 2 | 07-25-2009 09:35 AM |
Distortion of Recording When Playing Back Recording | acs | Pro Tools M-Powered (Win) | 2 | 03-18-2008 04:29 PM |
recording and playing back the guitar | przerams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-13-2007 07:57 AM |
7.3.1cs3 MIDI not recording or playing back right | audiogeekzine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-25-2007 12:15 PM |
recording drums into PT LE while playing back mix? | dubrichie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-11-2005 02:08 PM |
