Automation Problem
Help please, when i was using PT6.7 my automation worked fine, then i upgraded to 6.9 and all of-a-sudden when i try to use auto read it does not work. i have to use auto latch. the problem is when trying to use auto read for mute it does not stay muted. its reading every time i hit mute but it just does not stay muted. I did the update to 6.9.2 and had the same problem, so i did the update to 6.9.2cs4 and i still have that problem. by the way, after installing 6.9.2cs4, is it supposed to read 6.9.2cs4 when loading protools because mine still say 6.9.2.
Using Dual Power Mac G5 os 10.4.2, Digi002 Rack. Thanks in advance. |
Re: Automation Problem
I've had the same problem.
With PT 7 around the corner, and the assumption that this is a little "glitch", I've been using Volume automation to get around it. I know it's a cheap fix, but it'll get me through for the next couple of months. |
Automation problem | seolwoo | Pro Tools TDM Systems (Mac) | 5 | 06-10-2008 09:09 PM |
Anyone Had This Automation Problem? | tomhartman | Pro Tools TDM Systems (Mac) | 1 | 04-06-2007 07:54 AM |
Automation Problem | rastro2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2007 09:55 PM |
Automation problem | jaketanner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-19-2006 06:10 PM |
Automation problem | Jeff Zubeck | Pro Tools TDM Systems (Mac) | 2 | 01-02-2002 04:43 PM |
