Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 03-01-2006, 02:51 PM
Recording Engineer Recording Engineer is offline
Default Command 8 With Pro Tools 7.0 Problem
I JUST posted this in TDM MAC OS section, but now I saw this section., so I though it should instead go here, so sorry for the double post.
After upgrading from Pro Tools 6.9.2 to Pro Tools 7.0, I thought my Command 8 stopped working. It was coming online when I opened Pro tools, but nothing else would happen. It would go offline when closing Pro tools. So I just now updated the firmware to 02.01.02 and now it's not even coming online when I open Pro Tools.
Then I realized I must assign the Command 8 in Peripherals, MIDI Controllers tab. Once I did that and did a shutdown and boot sequence, the Command 8 now stays offline no matter if Pro Tools is running or not. When I open Pro Tools, the MIDI Out 1 led blinks. When I close Pro Tools, the MIDI Out 1 led stops blinking.
Do you think going back to firmware 02.00.00 or earlier will fix the problem? Where can I download earlier versions.
Or is there a better solution?
I'm really needing to get this solved by the weekend.
Thank you for your time.
Old 03-01-2006, 05:21 PM
Phil Jeffers Phil Jeffers is offline
Default Re: Command 8 With Pro Tools 7.0 Problem
I'd just follow the general troubleshooting thread, trash preferences, run disk utility, re-install PT's. Leave your C8 off until your ready to put online through periferals (this is just a hunch, the last point, not from Digi). You should have it sorted before long. I'd stick with the latest firmware... perhaps re-install that also. Make sure you have the settings correct in Peripherals (MIDI ports... follow you getting started guide). I'm running C8 with PT's 7 without any probs at all.
Strange Command 8 problem riffmachine Pro Tools TDM Systems (Win) 5 09-21-2010 02:45 PM
Command 8 problem! Hr.Austmann ProControl, Control|24, Command|8 4 05-27-2010 08:00 PM
Command 8 With Pro Tools 7.0 Problem Recording Engineer Pro Tools TDM Systems (Mac) 4 03-02-2006 09:40 AM
Command 8 fader problem AuraMaris Studio ProControl, Control|24, Command|8 3 11-01-2004 01:59 AM
PT 5.1.1 Shortcut problem (command =), Please Help ! lukemaniak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-26-2002 09:34 PM
