Old 09-29-2022, 03:38 PM
huzzam huzzam is offline
Default Re: USB latency
USB 2.0 negotiate at 10 or 20 ms latency depending on features used by the drivers. Good luck going below that. Newer versions obviously faster, but the thing has not been designed for low latency to begin with.
My USB 2.0 RME Fireface UCX II gets just under 4ms RTL at 64 samples & 48kHz. 7ms at 128 samples. Not sure where you're getting your information, but it's incorrect.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 09-29-2022, 03:44 PM
USB protocol. But as Darryl proved, RME has found a way past it.
Old 11-28-2022, 05:47 PM
basslik's Avatar
basslik basslik is offline
I'm curious how the Digi 003 is able to achieve 32 buffer at 48k recording 18 tracks with some effects.
On a 5,1 cheese grader.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
MIDI recorded latency after playing with no latency genebackmusic Pro Tools 12 8 01-19-2016 02:36 PM
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
