resetting the hardware engine
How do you set your playback engine? I'm using a Steinburg UR 22 mkII mixer, but somehow, my playback engine reset itself to my computer motherboard's sound card, which is Realtek Digital output. Consequently, I can't open any ProTools sessions now (see attachment 1). When I open the Playback Engine, I don't see any options to type in my Steinburg mixer. (See attachment 2.) Where do I go to switch from my computer's sound card back to my mixer?
Re: resetting the hardware engine
Hey
Launch PT with the N key held down and choose the Steinberg interface when the popup window comes up and see of that helps. PS. You say "Mixer" but it is called interface just so there is no confusion os misunderstanding
What he said^^^ and if you are not able to select the Steinberg to be the "audio engine" in Pro Tools, your Windows is likely using the Steinberg as the Default Playback Device(Windows usually NEEDS to NOT use the interface, to avoid hardware conflicts between Windows and Pro Tools) The other possibility is the connection is bad(bad USB cable or you forgot the required system tweak of UNchecking the Power Management feature on all USB ports(aka "USB Root Hub" in Device Manager)
Last night when I opened ProTools, I automatically got a pop-up that allowed me to select my Steinberg interface. Everything went fine, and I was able to record and edit as usual. Tonight, no. What is going on here? |
Did you go into Sound>Properties and set Windows to use the Realtek as its default playback device?
The connections are good, and the USB cable itself isn't the problem. I've never had to deal with power management on the USB ports in the Device Manager, since I use only 3 or 4. |
No, I set it to the Steinberg, as you can see.
Windows should not be using your Steinberg interface as it will tend to take over and stop PT having access. In my case the Realtek output goes to a patchbay and can be plugged into the monitors there. USB power management settings stop the USB ports powering down if they detect no activity.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Another question: Could you possibly send a screen shot of where you can change the USB power settings? Thanks! |
HD OMNI not showing up in Hardware / Playback Engine Tab. | rpmprod | Pro Tools HDX & HD Native Systems (Mac) | 3 | 01-20-2017 03:25 PM |
Upgraded Hardware/Playback Engine Issues | WeaselFlix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-21-2010 07:49 PM |
Cannot recognize Digi Hardware - resetting firewire drives? | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-04-2007 09:44 PM |
Resetting 002 Hardware | BenTerry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2004 11:54 AM |
HD hardware and playback-engine settings? | Allan Speers | Pro Tools TDM Systems (Mac) | 8 | 10-03-2002 05:47 AM |
