  #51
Old 04-21-2009, 12:59 PM
Default Re: What's the fastest and most stable CPU/Motherboard combo right now...
Originally Posted by WATYF View Post
Right, but I hadn't installed any plugins yet. All the tests I've mentioned so far were done before a single third-party plugin was installed.
WATYF
actually pull out everything in the plugs folder!! all digi plugs. the new air plugs have been little buggers as well. especially db33 and minigrand and structure on occasion. just pull everything out and eliminate the possibility.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #52
Old 04-23-2009, 04:05 PM
WATYF WATYF is offline
Two more possibilities eliminated.
It's not related to any plugin. I pulled every plugin out of the folder and got the same results (6088 errors all the time).
It's not related to the digi hardware. I brought in a 002 console and hooked it up and had the same exact issue.
WATYF
  #53
Old 04-23-2009, 04:31 PM
And here are the benchmarks from that software someone mentioned earlier. I've tried recording to each of these drives, with the same result.
O/S Drive (150GB Raptor)
Audio Drive (150GB Raptor)
Test Drive (Lacie 500GB 7200RPM external)
WATYF
  #54
Old 04-23-2009, 07:20 PM
JPS JPS is offline
WATYF,
Your HD tests look pretty good on the OS and Audio drive. Lacie looks a bit slow. I think you have been able to eliminate quite a few things, including your 002 as the possible problem.
Let me asks a few more questions.
1) If you open up 8 new tracks in a new session, record enable, then record, do you get this error?
2) Do you get the errors on all your sessions, or just one session in particular?
3) You mentioned a session with just 2 tracks where you tried to add 8 additional drum tracks and got massive errors. You might try this. Consolidated the audio tracks and import them into a new session, then added 8 tracks, and check to see if you still get errors? If no errors, it could be a corrupt session file. If you get errors...I'm stumped...
I generally don't record at 88.2, but I did a small session with 10 tracks at 128 buffer and didn't get any errors. Your hardware looks pretty good, so I would have to lean toward some sort of a software issue. Obviously, these types of issue can be frustrating and take quite a bit of work to solve.
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz
  #55
Old 04-23-2009, 07:42 PM
If I open a brand new 88.2 session (not using a template) and add nothing but 8 mono audio tracks, arm them, and hit record, I get an immediate 6088 error.
WATYF
  #56
Old 04-24-2009, 06:18 AM
The account I'm using is an administrator. On the previous install (when the problem first started), the only user on the machine was the windows administrator account.
WATYF
  #57
Old 04-24-2009, 06:21 AM
JPS JPS is offline
WATYF
Ouch!!!
Well, the "Run as Administrtor" is certainly worth checking, cause it has solved or improved some unusual problems.
I'm stating to get low on things to check... but I would examine again your settings on the "power saving" features. Some of these features can power-down the PCI bus, as well as other critical settings. Some of these are in the BIOS, others are in Power Options in the Control Panel. Gigabyte has an Overclocking and Power Saving program that installs when you load your motherboard drivers. If that program is installed, I would uninstall it. I think they are called "Easy Tune" and "Easy Energy Saver".
Usually, when I get a -6088 error I look for something that can affect the firewire. So, a powered-down PCI bus would qualify. But since you had the same problem across two systems, and one was an Asus system and the other a Gigabyte, that does cast some doubt on this theory...but I would check to make sure the setting are correct.
  #58
Old 04-24-2009, 11:07 AM
mykhal c's Avatar
mykhal c mykhal c is offline
For the record, I did a DVerb test (using PT 8.0) and got 175.
Storage Devices
WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache) : 140GB (C:) (D:) (E:) <====????
WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache) : 140GB (F:)
WDC WD10EACS-00ZJB0 1TB (USB, 3.5", 5400rpm) : 932GB (G:)
BENQ DVD DD DW1650 (RAID, DVD+-RW, CD-RW) : N/A (H:)
Logical Storage Devices
WindowsXP (C:) : 18GB (NTFS) @ WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache)
Programs (D:) : 39GB (NTFS) @ WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache) <===????
Storage (E:) : 83GB (NTFS) @ WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache)
AudioFiles (F:) : 140GB (NTFS) @ WDC WD1500ADFD-00NLR1 150GB (SATA150, 3.5", 10000rpm, NCQ, 16MB Cache)
CD-ROM/DVD (H:) : N/A @ BENQ DVD DD DW1650 (RAID, DVD+-RW, CD-RW)
3.5" 1.44MB (A:) : N/A
BACKUPS (G:) : 931GB (FAT32) @ WDC WD10EACS-00ZJB0 1TB (USB, 3.5", 5400rpm)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
Audio Device : Giga-Byte HD Audio Controller
Serial Port(s) : 1
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
what is your reasonin' behind your partition config??? this 'might' not have anythin' to do with your 6088 error but do you install your executable programs on this separate partition??
WATYF
have you seen this documentation regardin' 6088...
6085 and/or 6088 errors with FireWire Digidesign or M-Audio interfaces on Windows XP.
If you are experiencing -6085 and/or -6088 errors in Pro Tools when using a FireWire Digidesign or M-Audio interface (002, 003, Mbox 2 Pro, FireWire 1814, FireWire 410, ProFire 2626, etc) and have an eSATA/RAID card with a JMicron controller, you may be able to resolve the errors by updating the driver for the JMicron controller.
Download the latest driver from the manufacturer, then go to the Device Manager, right-click on the controller and select 'update driver', then point it to the newly downloaded driver.
This workaround was reported by a customer and is not supported or tested by Digidesign.
also have you checked...
1) possible IRQ conflicts?
2) adjusted your DAE disks settings in preferences?
3) adjusted your cache settings in preferences?
4) tried an approved PCI F/W card?
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #59
Old 04-24-2009, 11:33 AM
That's the old Sandra report (I posted a newer one later in the thread). Yes, I had a separate partition for installing Programs. No, it had nothing to do with my problem, as I proved when I reinstalled my entire system on one partition and still had the exact same issue.
I've downloaded the latest drivers for my motherboard. I'm not sure what else I can get to update the JMicron controller.
1) How would I know if I had one?
2) Adjusted them to what?
3) See #2
4) Yes.
WATYF
  #60
Old 04-24-2009, 01:26 PM
mykhal c's Avatar
system => device mgr => 'view' tab => select 'resources by type' => then look at devices usin' the same IRQ to see if it denotes any conflicts
for your raptor drives i would set it to '0' (best performance) then see if that and changin' the cache setting helps. change one thing at a time...of course
3) See #2
4) Yes.
WATYF
most stable OSX/ PT 10 combo? mr xy macOS 1 11-07-2012 05:54 PM
What's a stable OS 10.2.x / PT combo? Studio Dweller Pro Tools TDM Systems (Mac) 4 03-11-2004 08:01 AM
Most Stable OS/PT Version Combo? Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 01-29-2004 09:58 AM
What is the fastest motherboard out there? iguitaryo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-14-2003 05:03 AM
Fastest/Stable System for Digi 002? (money not an object). Booyah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 80 02-07-2003 08:44 PM
