can you record in at half speed
i know you can playback at halfspeed.
my ? is can record in at half speed and if so how? thanx in advance
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
Re: can you record in at half speed
Why would you need to do this?
And you can't do this anyway! Mike |
Hi, it's possible with elastic audio (in version 7.4), I've been toying with this recently. Make all audio tracks tick based and select polyphonic, then change to slower tempo and record, then return to original tempo. However quality depends on how much speed has changed. Select X-Form and render for better quality...
"Shift + F12" for half speed record on a PC.
Of course you can do it !!!!
especially for giddy speed guitar solo or hard part. But remember you have to change the tune (can't remember how much down). Cause at normal speed the tune is gonna be lifted up. You can also use Elastic processing (then you don't need to detune). If it's in a full mix it's okay but in a few tracks parts or one instrument part like a piano solo...you can hear the processing artifacts, so it's better then to practice and have the most natural sound at session speed.Even if you manually move some notes manually there after (classical editing)with crossfades...You're in digital world so you can do as many takes as you want, even paste some different parts from some differents takes (montage).It's not cheating it's just studio work. Hope it helps. |
something you could try thats worked for me (no elastic audio or retune):
say you have a bass part and a drum part, both 4 bars, and you want to record guitar. use TCE to stretch the bass and drums to double the length (ie make 4 bars 8 bars) practice the part a few times then record TCE bass drums and guitar in half (8 bars to 4) doesnt always sound perfect, but might work.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Really??? I thought I would see solid answers here. Hold down shift when you press your record button(s), command + spacebar, F12 or 3 on the numeric keypad, play 1 octave lower than regular.
On mac I found I had to first hold down shift - command, while holding click the record button in the transport to arm it, continue holding down shift - command and then hold the space bar as well.
Technically the shortcut is Command - Shift - Space Bar but it only works for me if I do what I described above |
Half Speed Midi Record | MoreMolecules | MIDI | 0 | 09-29-2008 12:27 PM |
Bug: Click is strange in half speed record | Niljam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2005 03:10 AM |
My first 6 bug...half speed play/record doesn't work. | mike connelly | MIDI | 5 | 07-16-2003 08:32 AM |
Half-speed record? Automation | summersleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 06-08-2003 09:34 PM |
Is there any way to record at something other than full or half speed in PT? | PUCK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-11-2002 12:10 AM |
