Old 11-11-2005, 04:08 AM
toddm7 toddm7 is offline
Default Changing tempo w/out changing midi performance???
Is there a way in pro tools to change the tempo without altering the timing of the midi performance?
I recorded some tracks along to some pre-recoded audio without setting the tempo. I now need to go back and clean up some stuff using the grid and a little quantize, but now when i used the indetify beat function to get the correct tempo, my midi plays slow and out of time with the original audio. Is there a way?
PT 6.9
Thanks in advance.
HP Laptop
Old 11-11-2005, 04:39 AM
bb_aus bb_aus is offline
Default Re: Changing tempo w/out changing midi performance???
you can with Pro Tools 7
Sample-based MIDI tracks allow MIDI events to stay locked to time code regardless of session tempo changes
Old 11-11-2005, 04:42 AM
Thanks. A good reason to upgrade.
HP Laptop
Old 11-11-2005, 08:48 AM
jofromabove jofromabove is offline
You can also use the TC/E tool on the midi region to get that midi back on beat.
j
Old 11-11-2005, 10:51 AM
j
Thanks. How? When I selected a midi region, the time strectch tool had no effect.
HP Laptop
Old 11-11-2005, 11:11 AM
Did you use the TC/E-trimmer tool?
Its done just as you timetrim audio. Midi track has to be showing regions.
j
Old 11-12-2005, 10:35 AM
casperfun casperfun is offline
well I have PTLE 7.0. But I you can use the newly implemented tick based recording to keep your your audio and midi the same when changing tempo.
PTLE 6.9 implementd tick & sample based recording. The tick part was new.
Best as I can remember, change some little panel button into a diamond I think in the channel. I used it for a song.
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Changing MIDI Tempo ? polaredit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2007 03:52 PM
changing tempo without changing pitch Sharabelle Pro Tools TDM Systems (Mac) 3 02-10-2007 05:19 PM
midi and tempo changing dubman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2005 03:57 PM
changing tempo without changing midi wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 05:40 AM
