Old 08-16-2018, 04:14 PM
Siegfried Meier Siegfried Meier is offline
Default Command 8 - Meters Not Showing in 2018.7
Hey guys,
I noticed meters aren't showing anymore on the Command 8 in the latest version...is there something I need to turn on to make this work? I've never not had meters work on this thing...
Thanks!
Sig
Old 08-16-2018, 04:16 PM
Default Re: Command 8 - Meters Not Showing in 2018.7
Ahhhhh if Eucon is checked off, the meters don't work...for whatever reason.
All good now!
Thanks,
Sig
Old 08-17-2018, 12:55 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
That's normal, unfortunately. I discovered this when using PT Control. Eucon takes the meters away from HUI devices.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 03-01-2019, 08:50 PM
maaaquemeseyo maaaquemeseyo is offline
PT 2018.12, OSX 10.13. I have the same problem, when I activate Eucon I lost meters in all my HUI devices. I hope this is a bug, since I both at the same time.
Old 03-03-2019, 12:29 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
Yep, that is the issue. If you are using Eucon the meters on a HUI device will not work. Eddie Jones from Avid has said that "there are technical reasons as to why this doesn't work. It's not a supported workflow".
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 03-03-2019, 11:09 AM
ron meza ron meza is offline
it's not a bug ........
it's a FEATURE
Old 03-14-2019, 09:53 AM
Chyles Chyles is offline
Hi
So the Command 8 works fine with the newest Apple OS Mojave and Pro Tools 2018?
You all have no problems?
Thanks
Chad
Old 03-16-2019, 10:12 AM
bartosz idzi bartosz idzi is offline
Command 8 works with OS X Sierra and Pro Tools 2018.12. Cannot find a reason it would not under Mojave :)
Bonus question - so you can use Eucon Artist mix and command 8 at the same time? Or Dock or anything other Eucon-based with C8?
2018 Master fader meters mikeyman Pro Tools 2018 3 08-01-2018 12:12 PM
PT 12 Meters Not Showing Red (clips) Oroz Pro Tools 12 12 10-06-2015 05:38 PM
edit window not showing clip on a meters dmitri85 Pro Tools 11 9 10-25-2014 03:03 PM
no audio or meters showing on playback P,B,S Pro Tools 11 0 06-25-2013 05:45 AM
XMON central meter section not showing meters tonmeistermat ICON & C|24 2 11-15-2006 04:38 AM
