Old 01-28-2017, 07:30 AM
KV626's Avatar
KV626 KV626 is offline
Default export AAF...no automation?
I was under the impression that AAFs included automation...well...when I create them in Logic or DP, volume automation shows up in Pro Tools, when I create them in Pro Tools (12.7), nothing... Is this a known issue or maybe I'm missing something?
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 01-28-2017, 09:18 AM
john1192 john1192 is offline
Default Re: export AAF...no automation?
could it be on the DP or LOgic end, NOT reading the automation made in PT ?? i have logic here on a separate drive that i could test later ... have not had to do this for quite awhile ..
btw: and which version of Logic ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-28-2017, 10:26 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Did try to import that AAF again to PT to see if the automation is there?
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 01-28-2017, 05:34 PM
KV626's Avatar
What I meant was:
- when I create an AAF in Pro Tools and then import it in PT, the automation is not there all my faders are at 0.
- when I create an AAF in DP or Logic and then import it in PT, the automation is there.
...How come Pro Tools doesn't even read the automation from a file that was created in Pro Tools, whereas it sees/reads it when it comes from another DAW?
Old 01-28-2017, 05:43 PM
KV626's Avatar
Yup, it's not.
I didn't even try to import it in Logic or DP as I have to make sure it opens properly in Pro Tools. I'm exchanging files with other studios that need to import them in either Pro Tools or MC (or FCPX). If it were just Pro Tools I would give them PT sessions but MC or FCPX can't deal with native PT sessions, so I need to make AAFs... As a compromise I made stems so I didn't have to bother about automation but it's not a final mix, and stems are a waste of time at this point.
Old 01-28-2017, 05:48 PM
KV626's Avatar
10.2.4 and 10.3. But as I said above, the issue is that Pro Tools doesn't seem to export any automation at all in the AAF, but it should, no?
Old 01-28-2017, 09:35 PM
smurfyou smurfyou is offline
Did you check "Enforce Avid Compatibility"? For OMF exports that disables volume automation. I don't recall if it's the same for AAF.
~Will
Old 01-30-2017, 05:07 AM
KV626's Avatar
I think I tried both actually but now I have doubts . I'll check again and report back...
Old 06-08-2017, 09:30 AM
richists richists is offline
Did someone find a solution? I'm having this issue as well. It's annoying as I have to send some AAF's to an editor. It just makes no sense for him without the automations.
Old 06-08-2017, 04:02 PM
for going to another Pro Tools System using AAF or OMF - turn off Enforce Avid Compatibility - then the Volume auto is included .. i cannot find a way to add mute or pan info ..
for going to another DAW (i tested Cubase Pro 8) - i could only get Clip Gain to translate over via OMF - Clip Gain was changed to Volume Automation in Cubase (you have an option for this) .. otherwise i could get NO Automation to pass from PT to anything else ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Volume automation in omf export Chris Nuckols Post - Surround - Video 3 08-22-2012 07:42 AM
REGION GROUPS do not carry automation on export soundtrane macOS 0 03-28-2011 10:04 AM
OMF Export from PT with Volume Automation Ginger Post - Surround - Video 1 03-25-2010 12:02 PM
FCP 6 OMF Export/PT Import with Vol Automation Problems i hear dead people Post - Surround - Video 5 06-04-2007 04:54 PM
Trashing DAE Preferences - Export Automation digi98 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-21-2001 07:57 AM
