Old 01-06-2010, 12:51 PM
beauhero beauhero is offline
Question when connecting the new iMac quad to the 003 rack?
Can the hard drive space be used on the drive that is being used to connect the 003 (with FW400) to the iMac(FW 800)?
Im using the 27" quadcore iMac and I need to get a hard drive to daisy chain the 003 rack to the iMac due to the iMac not having FW 400. But what I need to find out is, can I use that hard drive to record on?
Any help would be most appreciated. I don't want to find out the hard way.
Old 01-06-2010, 01:04 PM
Default Re: when connecting the new iMac quad to the 003 rack?
Yes you can but it will run at FW400 speeds.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 01-06-2010, 02:56 PM
zodo zodo is offline
FW800 to FW400 cables are also available and work fine.
Old 01-06-2010, 06:15 PM
nst7 nst7 is offline
I've used 3 hard drives in a row plus a 003R daisy chained with no problems. Using the hard drive as an adapter is the easiest way. You record on the drive plus it serves as a 800 to 400 adapter.
Old 01-07-2010, 04:03 PM
Thank you all! I kind of took a gamble going from a G5(pre-intel) so I didn't know what to expect, and when I found only one FW 800 I panicked.
Using the new Quad iMac? jazzhawk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-05-2011 01:39 PM
i7 iMac, 27" quad and pt 8.0.4 mozart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-30-2010 06:02 AM
New iMac Quad Core bradch00 Pro Tools M-Powered (Mac) 0 03-02-2010 11:51 PM
iMac Quad Core i5 vs i7 Dave D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-11-2009 10:50 AM
IMAC or PC Quad Core Mycolorizred Pro Tools M-Powered (Mac) 21 09-10-2009 09:11 PM
