Digidesign 192 A/D input card issues...
Hi -
I have a blue Digidesign 192 analog I still enjoy using. Everything clocks perfect (to an Apogee Big Ben) and all digital connections and analog out connections work and sound perfect. My problem is my 8 channel A/D input card has started making audible crackling noises, some channels seem worse than others. My question is if I replace the card am I likely to fix the problem? I opened the case and tried re-seating the ribbon cable, it didn't help. Around $200 to replace the card with a used one on eBay which I can stomach financially but only worth it to me if it works. I enjoy using this card with my Digidesign PRE which works perfect and I tested, so I know it's not the PRE. Anyone else ever have this problem. I'd really rather scope out a replacement card in the $100 range so if anyone has one they wanna sell me, I'm at [email protected]. Thanks!
Justin (Proud Pro Tools Ultimate PERPETUAL license owner) Admin www.elevenrackpresets.com Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD |
Re: Digidesign 192 A/D input card issues...
Justin,
Before you go out and spend money verify that your Big Ben is outputting the same reference as your Pro Tools system such as 23.98 on your Big Ben and 23.98 on your Pro Tools system. Make sure the session rate and the reference are the same. Sometimes it's good to power down your reference and reset it again. This applies to 24 frame or Word Clock reference . Make sure all your cables are connected firmly. I have had issues with a cable being bad and then clicks on everything you hear back.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
I also would recommend checking and cleaning all connections before buying another card
Thanks I appreciate the tips and advice. I’m sure it’s not the word clock. I picked up a used 192 blue on eBay with 2 A/D input cards (as opposed to one) for $330 shipped. Cheapest option. I’ll try and re-sell my old 192 (with full disclosure about the card of course) or keep it as a spare. It’s a great bargain compared to more expensive ones and I reject those who say 192’s don’t sound good, so many records made with them!
Hi Justin,
My 192 is experiencing the exact same issue as yours. Only the analog input is very crackly, seems to be a VERY hot level, and the trims don't seem to do much. Did you solve your issue or just replace? I'm going to open up the 192 and double check all the connections inside and see if that helps.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
QUOTE - and the trims don't seem to do much. - QUOTE
I asume you set the trims in PT's calibration mode ? You can not just turn those pots without knowing what you're doing. First calibrate the output, after that, connect the output straight to the input, and calibrate the input. Check this page: http://akarchive.digidesign.com/supp...ation_Mode.pdf Good luck.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11 16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1 MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch + madi baseunit + optical SFP 1300nm MOM v.1.0.1.4 by DAD Genelec 1237A Sam, Avantone active mixcubes LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro Furman P1400 AR E Power conditioner Live-rack: 1x HD Native TB, 4x 192 I/O (64ch AD) 8x Yamaha HA-8 micpre, Rosendahl mif4, Genelec 1031A, Presonus Monitor Station Last edited by Johnny Hulst; 12-29-2020 at 06:47 AM. |
Known old problem, diodes start to make noise from overheating. When replacing them, they are raised a little higher from the board itself.
Details are described here: https://groupdiy.com/index.php?topic=41713.0 and here: https://www.gearslutz.com/board/geek...1-2-input.html Last edited by BernVi; 12-29-2020 at 10:45 PM. |
Trade my 192 output card for your 192 input card | velvettone | Buy & Sell | 1 | 04-16-2018 07:15 AM |
FS: Digidesign HD Core Card and Accel Card - PCIX/PCI | N1h1l1ty | Buy & Sell | 7 | 05-30-2015 10:35 AM |
WANTED: Host card for Digidesign Expansion HD chassis (pcie ethernet card) | topdiggy2 | Buy & Sell | 0 | 02-04-2015 08:22 AM |
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
Win 7 - UA Apollo working, with Digidesign 003 as Midi input | Tripledweb | Windows | 2 | 03-17-2013 08:48 PM |
