Old 03-15-2018, 07:11 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Clip dragging bug
This is very odd: when I try to drag some clip from one track to another it affects other clip strange behaviour.
It creates a very long fade even though the file is not long enough for that!
The other clip is a different file not related to the dragged one.
PT HD 2018.3
Anyone saw it? I can reproduce it 100%.
Please see the video:
https://youtu.be/F0aW455JFIA
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 03-15-2018, 10:20 AM
reichman's Avatar
reichman reichman is offline
Default Re: Clip dragging bug
Not seeing it here. I'm also on 2018.3. Is there a broken clip group in the edit window? Does it happen if you disable Layered Editing?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-15-2018, 12:18 PM
mgoorevich's Avatar
No Clip groups used on these files. The Layerd Editing check / uncheck doesn't have any effect. "Preserve Fades with Editing" doesn't change anything
The only work around is to make a Clip Group from selected regions I am trying to drag on the video. Or fully delete all the fades and crossfades inside of this selection...which is not a solution.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 03-15-2018, 05:11 PM
laki laki is offline
Definitely seeing it here. I have not been able to establish what makes it happen.
It happens to me during reconforms.
Turning layered editing on seems to make it work correctly.
Old 03-15-2018, 11:43 PM
mgoorevich's Avatar
I am getting sick with this bug. Is it only me who is experiencing it?
It happens to me so often but with random clips.
Now I saw an AS processing behaviour (also happens with a consolidate clip Shift+alt+3)
https://youtu.be/pzfSVYQq7WA
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 04-18-2018, 10:06 AM
mgoorevich's Avatar
This is the video of the bug:
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
HTML code is On
Dragging a Clip to New Track adam79 Pro Tools 12 10 01-20-2018 02:45 PM
Pro Tools Quits unexpectedly after dragging a clip to the timeline Inglesworth Pro Tools 12 1 03-23-2017 06:09 AM
Clip Dragging Issue Porky Pro Tools 12 6 12-07-2016 08:08 AM
Dragging Clips from Clip window - ALWAYS Vertical sort!? davedotpez Post - Surround - Video 2 05-20-2015 07:24 PM
10.3.8-When vertically dragging a clip that shares a crossfade... STILL DOESN'T WORK simonchase Pro Tools 10 0 01-01-2014 02:14 PM
