  #71
Old 06-03-2019, 03:50 AM
Southsidemusic's Avatar
Default Re: Pro Tools cannot find (all) my aax plugins.
Those versions won’t work with PT11 and above as you need the AAX64 bit versions which are a paid upgrade as stated in unKJE’s post above.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #72
Old 06-04-2019, 07:28 AM
JesperT JesperT is offline
Hi Darryl. With the great support from you and UnKJe and Christoffer my Pro Tools issues with Velvet and structure is now solved (-: (-: ( double happiness )
Maybe one day we can meet on Hamilton Ave and enjoy a avocado sandwich at Joe and the Juice.
best regards
Jesper
  #73
Old 06-04-2019, 08:24 AM
Thanks for the kind words and Glad to hear you solved this. We are here should you need any assistance moving forward!
All the best and maybe we can meet for a cold beer this summer as my brother and I always drive one of our porsches down to Rimini and cross Europe on the way down so we are stopping in Denmark every year before next stop Amsterdam on the way down
Be well and talk later brother
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #74
Old 06-05-2019, 02:24 AM
Hi Christoffer. You are wellcome, and a stop before Germany might be needed. I think you will feel at home at my place ( Swedish Savsjo House ). Just let me know: [email protected]
'best Jesper
  #75
Old 06-13-2019, 07:31 AM
Hi Darryl
When I open Pro Tools this error window ( see attached file) pops up and I can't open Protools. Maybe you know what I can do to solve the problem ?
About back up I asked my dealer about Acronis and he said he couldnt find much information . He wondered why they offer two packages for 49 USD, when the one is for a lifetime and the other for one year ? and it was hard to see if it was back up to a usb hard drive or it should be to Cloud ?
I would be happy to hear your solution.
When I commit on the mac I use ζ ( danish letter) to get the selected down and p to get up. On the PC p works on the old session, which I have from the Mac. ζ is not working. If I create a new session on the PC none of them works ?
Also Memory location, when I use 0 (zero) and then a number on the Mac doesn't work on the PC.
Do you know a link where you can see short cuts from both Mac and PC which contain these options ?
Best Jesper
  #76
Old 06-16-2019, 03:00 PM
Originally Posted by JesperT View Post
Hi Darryl
The best thing when you get an assert it to try to google the error
like google this...
"CFicAAXWidget.cpp" "assert"
maybe add site:duc.avid.com onto the end of that search to only search DUC.
And with maybe a little looking around that will turn up this...
http://avid.force.com/pkb/articles/e...t-cpp-line-822
See if that helps. Don't worry the line numbers are slightly different, my first suspicion is this is the excact same cause. Line numbers likely have changed slightly because the Pro Tools code has changed between versions.
To answer the question in your PM, the E: here is not on your system. It's the drive containing the source code on the development system where Pro Tools was compiled. An assert is a simple programming way of checking something. A developer literally puts in a line of code like assert(color_name=='RED') and if that test is true nothing happens, and if false the program deliberately crashes with an automatically generated error message that includes in what source file and source code line number that assert is. Nothing at all user friendly about this, all designed for developers. Many of the more frequent assert error messages show a bit of laziness from Avid developers. They ought to be putting in better error checking that returns user-friendly error messages. (Hi Avid developers )
About back up I asked my dealer about Acronis and he said he couldn't find much information. He wondered why they offer two packages for 49 USD, when the one is for a lifetime and the other for one year ?
I have no idea because all my Windows Systems currently live within VMware Fusion virtual machines on Macs and get backed up with the Mac (and no you should not run Pro Tools in a virtual machine).
But a general piece of advice.... there are lots of knowledgeable folks here who can help you--but they won't find your questions buried in long threads. Start a new thread titled something like "Acronis - what version do I get?". But even better search for that info first, using Google search like I showed above, I suspect this has come up here before.
You should likely do both. I don't consider something really backed up until it is is stored in three different places. Ideally using more than one backup product and type of storage in case one thing messes up. With each copy made from the original, not copies of copies.
Boot/systems drives... meh who cares the thing you want there is to be able to rapidly recover, boot directly off a clone. Worse case you go reinstall everything. But sessions and user documents etc. they should be much more valuable. I would certainly back those up to some type of cloud storage (I use Google Drive mostly) as well as onto external disks, maybe with some stored offsite, maybe optical media as well.
Think though what you are tying to protect against. Failure of the computer or drive, failure of the building (it burns down, floods, etc.), theft, or ta da... dumb finger mistakes.
I expect that "finger mistakes" is actually the leading cause of data loss. Do not leave backups connected to the computer where they can be easily accidentally destroyed. Whatever you do for backups test they actually work, and you can recover stuff, but be very careful... that's an easy time to screw up and delete/destroy stuff.
And the most likely time that a drive fails is when you are backing it up. So now you have a dead source drive, a likely corrupt or incomplete backup in a target drive. Never rely on just one set of backup media. Even with Acronis have a pool of external drives you rotate through. And label them carefully.
There is a Pro Tools Shortcuts Guide PDF already installed on your computers. Hidden in plain site in Help > Pro Tools Shortcuts
All your other questions are best asked in new separate threads. Post each question once in the best seeming forum area for each one.
pro tools first can't find plugins majselbaum Pro Tools | Intro Discussion 2 06-03-2017 07:17 AM
Fresh install of pro tools anyway to find 3rd party plugins Raoul23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-21-2010 03:46 PM
Can't Find Plugins. Help, Please!! lclebsch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-05-2010 12:24 AM
Can't Find Plugins Newkid1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2009 05:31 AM
Pro Tools doesn΄t find plugins:( (iZotope). Vill! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-19-2008 06:07 AM
