#51
Re: RTAS or memory problems?
Ok, i installed all plugin updates i overlooked.
I'll report at the end of the day how may errors i get. Thumbs up for you diving into this thing Digi!!! You had some questions: I installed Leopard over Tiger. And i'm comparing PT7.4 under Tiger against PT8 under Leopard. I'm not using 400 and 800 disks on the same bus. I only use a Canopus ADVC100 videoconvertor on it's own 400 bus. All my disks, which are all 800's, are on the 800 busses. On the Soundcode issue: I was referring to Neyrinck aswell. On your site you call it version 8.0, Neyrinck calles their latest version 1.0.3 as can be seen on their downloadpage http://www.neyrinck.com/Pages/download.php . Quote:
#52
After 7 dayz that should have been the first thing you did!!
Chris
#53
#54
same here + "not enough ram" warning sometimes. never had this under 7.4. i found out, it works better with 4 cores than 8 cores. possible? Mac Pro Quad Core 3GHZ OS 10.5.5. 5GB Ram 4 x 750GB HDs Pro Tools HD3 Accel Version 8cs1 192 I/O C24 2 apple cinema displays 23 USB: 2 iloks & 1 syncrosoft dongle NO external HDs Ethernet: C24 Leopard fresh install (new HD) fresh PT 8 fresh install of all plugins (updated) i checked today again with the digidesign leopard list! i can send the plugin list, if needed, but is there possibility to get the list out of my mac, without writing down everything? i will also save the crash report next time. how can i do this, without posting pages here? this is the same mac i use before under PT7.4 edit: from the other thread: i still have the structure crashes when i edit something in tructure. i get a 2sec loop and than freeze. sometimes even "force quit" don´t work anymore. in 7.4. also structure crashes PT while editing, but without loop/freeze. like "bang" and there is the desktop. no crash report, nothing. another one: C24: this was also in 7.4. and is still there. from time to time when i press the insert knob on the C24, the C24 freeze. p.s. my english is not that good |
#55
I've been getting less errors and have the feeling it's speakerphone that causes the problem in my setup. The latest version of speakerphone comes with an older pacedriver than the current latest driver i have installed.
Maybe that messes things up? In a fresh session with only one track with Speakerphone on it, i can't select/deselect the different components like eq, tuning etc. Dusty Angel: Select all the plugins in the finder, press apple-c, paste it in any texteditor. You do have to add you versionnumber by hand though. Chris: get a life |
#56
"Pro tools 8 upgrade information - READ THIS FIRST!" It is critical that you have the minimum required version for any plug-ins installed. Information on minimum versions can be found here:... Right, off to get a life
#57
New session, 1 track, as soon as I put Ozone (1 instance) on it I can not even hit play! BUT, with 2 tracks and two Ozones (one on each track) everything works ok. PLUS, 16 tracks, with 16 ozones (one on each) and everything works too. Now that is strange!!! How can my computer play with 16 ozones and get erros with just one? It happens with some others plugins also. I'll do more tests as soon as I have time and I'll let you know. Is this happening to someone else?
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
#58
#59
If you have a secondary internal drive, I would test without the FW800 drives attached and see what happens. Keep in mind that you should also have audio and video on different drives and that those drives must be of the same type (firewire, SATA, etc). |
#60
You may have to run the Plug-in version generator twice to get it to include the version numbers. It's a bug that we're looking into and, hopefully, will have fixed shortly. |
Strike RTAS - Memory Issues | FierceBrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-26-2008 09:13 AM |
Please help on memory usage w/RTAS plug-ins | el biciclista | Pro Tools TDM Systems (Mac) | 6 | 12-11-2006 03:27 PM |
Kontakt RTAS PC Digi002 Physical Memory Low ,-9128 | skizzee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-04-2004 12:35 PM |
RTAS and REWIRE performance?? free memory needed?? | dk01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-23-2003 12:09 PM |
RTAS and memory | MacPhearson | General Discussion | 1 | 02-09-2001 08:31 PM |
