  #41
Old 05-11-2020, 08:22 PM
rinky rinky is offline
Default Re: Pro Tools HDX2 working on new Mac Pro
I ordered the Belkin cables but none fit the HDX or the power supply to the mother board.
Thankfully, I saved the original box that the HDX came with.
It contained a cable that worked.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
  #42
Old 05-12-2020, 03:04 AM
LukeHoward LukeHoward is offline
Is anyone running HDX2 on a new Mac Pro with a MTRX, and having weird issues having to restart Pro Tools when changing sample rates? (Specifically, it thinking that the number of interfaces has changed?)
https://lukehoward.com/
  #43
Old 05-14-2020, 06:17 PM
Pablo L. Pablo L. is offline
Hi.
I just received this statement from Avid support relating to slot order and cables.
The one with 3 connectors can be in the top slots 5-7. This is not qualified, but it is working (that is how we ran at NAMM). To run in the lower slots, you need an 8 pin to 6 pin cable from the Belkin cable lit from the Apple Store (only place to get it), and also a large 6 pin to 3 smaller connectors from Sonnet.
  #44
Old 05-14-2020, 06:19 PM
Originally Posted by Pablo L. View Post
Hi.
It must also depend on the cable length (or perhaps how far one is willing to stretch it), because the 6 pin cable I had used in my MacPro5,1 worked fine for me with the cards in slots 2 and 3.
  #45
Old 05-15-2020, 02:42 AM
Marsdy Marsdy is offline
Trying to fathom this as my nMac Pro is due today!
The upper Aux power socket on the motherboard is 6 pin, the lower two pairs are 8 pin.
What I’m wondering is - are the Aux power sockets tied to PCIe slots? In other words - is the top 6 pin Aux power socket tied to PCIe slots 5 to 7?
I was planning on using slot 5 for the HDX1 card since the Avid qualified slot 2 is blocked by a W5700X GPU. Slot 3 - Sonnet m.2 4x4 because that has x16 lanes direct to the CPU
Dave Marsden
UK
  #46
Old 05-15-2020, 05:26 AM
Yes, I did the same re: SSD placement. Anyway, you can get the power from wherever suits. It should make sense when it arrives!
  #47
Old 05-15-2020, 11:54 AM
paulschwotzer paulschwotzer is offline
My HDX card has a 4-pin connector as shown in the attached photo.
I see mention of 6-pin and 8-pin connectors, but no 4-pin.
I received my Belkin cable kit... no 4-pin connectors.
My MacPro is on order... I'm curious how HDX will get its power.
  #48
Old 05-16-2020, 06:29 PM
Dizzi45Z Dizzi45Z is offline
That confused me a bit too even when I had the cables all in my hands. The Belkin cable connects from the motherboard to one of the HDX cables that comes with the HDX card. I was coming from a Mac Pro 5,1 which didn't use the same cable I needed for the Mac Pro 7,1. Luckily I still had the original box for my HDX card and I noticed that it came with another cable that then attached to one of the Belkin cables (8pin to dual 6 pin). The 6 pin should connect to the HDX cable which then will have the 3, 4 pin connectors on the other end.
This, of course, is the configuration with installing in the Avid Recommended Slot 2 (second from the bottom)
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
  #49
Old 05-16-2020, 09:21 PM
MixerGuy MixerGuy is offline
Thanks for clarifying...
My situation is that I have an HDX-2 rig in a 2012 Cheese grater Mac, but i am 99.999% sure that I do NOT have the various other cables that came with the HDX cards originally.
So I only have the cables that are currently in use in the 2012 HDX-2 rig in my cheese grater.
any guidance as to what cables I'll need? It sounds as if I'll need the Belkin kit, but how do I survive without the various extra unused cables from the original HDX card box?
How would I obtain what I'll be missing?
thanks.
  #50
Old 06-01-2020, 11:41 AM
Alext11 Alext11 is offline
Dear All,
Juste adding my HDX2 to my MacPro.
All seems to working fine ! even the xxx Noise of Fans...
I'm on slot 3-4 (AMD 5700X on 1-2) and Sonnet 4m2 on Slot 5 with UAD on 6-7.
Any idea ? i'm so despite about it
HDX2 - HD IO 8x8x8 Jamie Mac Buy & Sell 1 08-06-2019 07:08 AM
2008 Mac Pro has more power than an HDX2 ? SmokinBaldMonkey Pro Tools HDX & HD Native Systems (Mac) 5 11-11-2012 05:15 AM
HDX1+96 IO to HD3 and HDX2+96 IO to backup betojapa VENUE Live Sound Systems 4 05-10-2012 05:34 AM
harddisks and HDX2 mr.armadillo Post - Surround - Video 1 04-23-2012 09:46 AM
Can I run HDX2 with two video cards in my Mac Pro? conrad787 Pro Tools HDX & HD Native Systems (Mac) 1 04-22-2012 08:46 AM
