Old 12-20-2010, 07:00 PM
theregentblue theregentblue is offline
Default Digi 002 in to a digi 002
I have a new amp book pro but it only has one firewire port. I have one digi 002 rack already but I have a chance to get another. Can I put the 2nd digi 002 into the 1st digi002 or do I have get a 2nd firewire port?
Old 12-20-2010, 07:03 PM
Slim Shady Slim Shady is offline
Default Re: Digi 002 in to a digi 002
You can't use two Digi002's on the same computer.
Dism Dism is offline
You can't use two 002s at the same time...
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-20-2010, 07:29 PM
There are much better ways to get more ins and outs than adding a second 002 anyway. Dump one and buy a Presonus D8 would be my suggestion(and that won't cost you a dime).
Old 12-20-2010, 08:22 PM
HD2 HD2 is offline
Couldn't you use one as the interface and the other for more inputs and then send those to the first via light pipe?
Old 12-20-2010, 08:41 PM
Nope... Not without using two computers, anyway.
D
Old 12-21-2010, 11:14 AM
caliberproductions caliberproductions is offline
Actually, it is very possible to use 2 digi's simultaneously on one computer.
I have done it, and got some excellent recordings i must say.
The trick is to simply route the firewire out of the first Digi 002 into a FW to AES converter (in bypass mode, of course)...and then patch that to into a ADAT machine (in record mode - but not necessarily recording on tape), feed the adat lightpipe output into the second Digi 002 which is hooked up parallel to the computer via serial interface, and then simply set Pro-tools to exteral sync mode.
Plug your second Digi 002 into your "amp book pro", and you are golden like a 7.
You can only get 16 bit this way, but it doesn't even matter if you bounce it all down in the end to a 4 track casette machine for extra "punch".
You can find these adaptors at Radio shack, or even home hardware these days.
Cheers,
Digi 002 not recognized by MacBook Pro - Digi CoreAudio not working GuidoC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-04-2011 09:37 AM
Digi hardware - bizarre behavior - Digi you will lose this market share andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 02-26-2010 07:45 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 10:08 AM
Digi - Reinstalled OS, PT LE, can't reauthorize Digi 002 pack plugins OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2003 04:20 PM
Wha is the name of the digi cable to hook up Apogee digi 8+ card called??? leon777 Pro Tools TDM Systems (Mac) 4 04-15-2002 02:44 PM
