Old 06-01-2004, 07:02 AM
paapje paapje is offline
Default save session copy in doesn\'t work access privilege
pro tools 6.4 tdm
os 10.3.2
rebuild permissions
when I do "save session copy in"
it works at first writing audiofiles to desination drive
but the an error comes up
COULD NOT SAVE A COPY IN COPY OF SESSION BECAUSE YOU DO NOT HAVE THE NECESSARY ACCESS PRIVILEGES (-5000)
I did rebuild permissions and that had no effect
please help
I have to move this session to another system
thanks
michiel
Old 06-01-2004, 11:03 AM
zr-rock zr-rock is offline
Default Re: save session copy in doesn\'t work access privilege
an expert did this:
go to the finder an select your drive..... choose "get info"
go to ownership & permissions / details
set everything to read/write and ownership to you
it's worth a try!
Old 06-01-2004, 03:03 PM
jimlongo's Avatar
jimlongo jimlongo is offline
First of all you should "search the Answerbase". There is a link at the top of the page . . . enter "-5000" and you will find a few clues like this.
Some other things you could try.
Choose the drive/s in question and (as long as it's not a startup drive) select the box "Ignore ownership on this volume".
Also check in the workspace browser that the drive is Labelled R under the A and V columns.
Finally (and this is my best guess since it seems one or more files in your session is causing this problem) choose the project folder in the finder, Get Info on that folder. Look at the details of the ownership, and click Apply to enclosed items.
HTH, jim
noise | jimlongo
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
Save Session Copy bug? TLarvenz Pro Tools TDM Systems (Mac) 2 05-17-2006 09:32 AM
access privilege errors... oneamazinkid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-28-2005 01:49 PM
Save Session Copy In removes files from session!!! Jay Nierenberg Pro Tools TDM Systems (Mac) 24 11-11-2004 05:25 PM
save copy aiff to sd 2 doesn't work smlworld Pro Tools TDM Systems (Mac) 2 01-21-2003 08:35 AM
