Sync isses, 9173, 9171 SOLVED
We had been experiencing a variety of problems ever since we installed the HDX card over two years ago - specifically intermittent MIDI sync problems, and ongoing intermittent 9173 and 9171 errors plus a variety of plugin-specific issues. We had opened two cases with Avid support, the last being a year ago, and after many dozens of back-and-forth emails, we were not able to stop the errors. I decided to open one more case before our subscription expired, and after a couple of emails, the tech support person said the 9171 indicates a communication problem with the HDX card, and he suggested i swap HDX cards with our re-seller, which we did. And sure enough, as soon as we installed the replacement card, the errors and sync issues were gone. It's unfortunate this wasn't caught sooner, as it has eaten up countless hours of investigation and rebooting and lots of grey hairs, but at least now it's solved. Avid has agreed to repair or replace the card under warranty because the issues were first reported while the warranty was valid, so i thank them for that, and i will be renewing our prescription. I thought some of you out there might benefit from this.
HDX PT 12.6 Mac Pro 6-core, 3.33 OS 10.11.4 Apogee 800 Aurora 16 |
Re: Sync isses, 9173, 9171 SOLVED
This could be a clarification
why some user have major problems , other not at all ! Maybe this was the problem with my HD Native card also ... |
Avid is still confused about the 9173 errors, together with a host of MIDI bugs; a true solution would definitely stop this bug that's been plaguing the greater majority of PT12 users for a very long time.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
dear dynamixaled , since i have , with a HDX card ,
also 9171 errors i would like to know more about the specific behavior of your faulty card. when opening a session , after starting PT , regardless if one or hundred tracks , strict dsp or mixed with native plugins , with or without video i get within 3 min an aae 9171 error.. mostly , if it happens once or twice , its gone till i restart PT. I have this behavior since installing the hdx card on PT10 , PT11 and recent PT12HD versions. On OSX 10.8.5 (PT 10+11) and sierra. I did had a case , onliest "solution" was the hint to use 1024 Buffer size (btw doesnt help and is a joke on a low latency DSP system for thousands of dollars). Since i did all known troubleshooting and i have a compatible macpro (5.1 8 core , 48 gb ram , lot of ssd and wd black) i come more and more to the conclusion its a faulty card regardless what digitest (no errors shown) says. I bought this card in may 2016 and i am not sure where and how to get a replace card , so far i know within a year (which is over) is the seller responsible or any guarantee and within two years the manufacturer... or am i wrong? any help welcome
foley artist , soundeditor |
Turning Off Hyper-Threading In OSX Solved Most CPU Spikes And -9173 | Bobogura | Pro Tools 12 | 12 | 04-14-2020 05:44 AM |
Constant 9173 error's PT 12.6 *solved* | Studio Llama | Pro Tools 12 | 29 | 11-25-2019 01:50 PM |
I solved my 9171 errors | fifty8th1 | Pro Tools 12 | 5 | 05-17-2016 04:17 PM |
CPU -9173 Error [Solved potentially] | teedeecee | Pro Tools 12 | 3 | 12-13-2015 03:30 PM |
Pro Tools 11.3.1 Error Codes -9171 -9172 -9173 -9129 -9093 | priyatsomo | Pro Tools HDX & HD Native Systems (Mac) | 11 | 02-27-2015 06:23 AM |
