Old 11-03-2010, 01:15 PM
velvettone
Guest
Posts: n/a
Default Heat challenge issue... hmmmm...
[EDIT] Just to keep this thread on focus, this is a thread regarding a TECHNICAL (non-subjective) issue with the "Heat Challenge". Comments like "If you don't like the sound of HEAT, don't use it." and "I can't imagine not having it in my studio." and "I like Heat so much, I wanna spread it all over my nekked wife" and "I hate heat so much, I wanna cap it in the dome" have nothing at all to do with the topic of this thread. If you feel the need to cheerlead, please post it in this thread:
http://duc.avid.com/showthread.php?t=280179
There is a technical issue with the Heat challenge. It gives the wrong answer to the last question regarding which summing method that you prefer.
I know this because I got a 100% on the challenge. When I answered the last question, I picked the answer that was positively identified as "Pro Tools only summing" in the previous set of questions, yet it came back and told me that I preferred the "Neve summed mix".
I posted this in the "heat challenge" sticky thread, but got nothing but crickets.
Old 11-16-2010, 06:06 PM
brettyc brettyc is offline
Default Re: Heat challenge issue... hmmmm...
I had the same problem. Wonder if there are any other errors on the survey?
Old 11-16-2010, 09:03 PM
WernerF WernerF is offline
If you like the sound of HEAT, use it. If you don't like the sound of HEAT, don't use it. Who cares what everybody else thinks
PS - I like the sound of HEAT and I actually use it.
My two cents...........
Old 11-16-2010, 09:55 PM
Anibal Anibal is offline
Thumbs up Re: Heat challenge issue... hmmmm...
same here
PT 2018 HDX 1
Mac Pro Westmere 12 core 3.46 OSX 10.12.5
64 gig ram
Old 11-17-2010, 01:31 AM
velvettone
Guest
Posts: n/a
Thanks for the informative replies... and the Pro Tools advice. I have no opinion about heat at all, at this point, as I have not demoed it yet.
THIS thread was started to point out to Avid that there is a major technical (non-subjective) issue/problem with their challenge. In hopes that they would somehow rectify the error. From the lack of response from them, it seems to me as if they don't care, or, are too embarrassed to admit it.
My assistant did the challenge too. Also had the same error. This is a MAJOR [bleep]-up for Avid.
Old 11-17-2010, 10:54 AM
drumster drumster is offline
I bought HEAT shortly after my 30 day trial expired a couple months ago, and I haven't regretted my decision at all. I really like what it does in the mix, and now I can't imagine not having it in my studio. There are some instances where it's not the right choice, but I find that it sounds good on most sources.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 11-17-2010, 11:52 AM
DigiTechSupt's Avatar
It's not that we don't care or are embarrassed - we just don't see every post made on the DUC.
With that said, I'll pass this along and make sure this is taken care of.
Avid Audio Tech Support
Support FAQ
Old 11-20-2010, 12:45 AM
rotfuhr rotfuhr is offline
I also did this test and got 6% correct, basically because I answered «I don't know» to all but one part. That one part was the last one, and I correctly identified pure Pro Tools summing as the correct one. That was the sample I preferred, but I got «you preferred Neve»!
Old 11-20-2010, 05:34 PM
velvettone
Guest
Posts: n/a
Has anybody out there scored 100% and selected the heat mix, or scored 6% correct, but only answered the last two questions, and picked Heat as the best sounding mix?
...did it report correctly, or did it report "you preferred the Pro Tools only mix"?
Old 12-02-2010, 10:39 PM
velvettone
Guest
Posts: n/a
Bump!
HEAT, NEVE 8048 Listening Challenge Tom Graham Pro Tools TDM Systems (Mac) 82 04-23-2015 07:43 PM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
pro tools 10 issue with heat papallion Pro Tools 10 12 09-17-2012 10:51 AM
pro tools 10 issue with heat papallion Windows 15 09-16-2012 07:30 PM
Anyone having the excessive heat issue with early 2009 Nehalam Mac Pros? MDH25 Pro Tools TDM Systems (Mac) 0 02-04-2010 03:27 PM
