GR4 PT 8.0.1 Win7
Anyone have a functional working RTAS Gutar Rig 4 in PT 8.0.1 with Win 7 64 bit (or Vista 64 bit)?
I have tried for weeks with the GR4 demo which NI claims is fully functional (for 30 mins) and should work as an RTAS. Native Instruments Support group has no answers other then there must be some incompatibility. Anyone?
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
Re: GR4 PT 8.0.1 Win7
very interesting. this makes me think that perhaps I should try to install on older GR3 which is 32bit and see if that works. This would avoid the whole 64 bit thing. Thanks for the suggestion. I will start experimenting and let you know.
BENONI, DUDE YOU ARE A GENIUS!!
Sure enough, while I didn't put the GR4 (64 bit) into the Program (x86) directory, I did install an older version GR3 (32Bit) which did go there and the results are simply ahwsome. If you are ever in ChiTown you let me know, I own you a tall cold one.
mac pro 1.1 for 64 bit win7/hdx | klaukholm | Pro Tools HDX & HD Native Systems (Win) | 6 | 12-11-2013 12:41 PM |
OK, Win7 x32 or Win7 x64? | Smurf43 | Pro Tools M-Powered (Win) | 4 | 07-23-2012 08:57 AM |
Here goes nothing - Bye Bye XP, hello Win7 | markus44uk | Windows | 17 | 10-02-2011 07:51 AM |
big BUG in PT8.03 under win7 X64 | 32768 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-05-2010 03:47 PM |
Win7? | Fullsound Recording | Pro Tools TDM Systems (Win) | 10 | 04-30-2010 09:44 AM |
