#31
Re: Win7 + HD 8.0.1
Musician,Producer etc.. PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio |
#32
Re: Win7 + HD 8.0.1
I'm not sure this will help the HD users but thought I would pass along this info.
I got the latest versions of Analog Channel TDM (when I bought it there were no LE versions) and the RTAS version of Compressor Bank LE to install on an M-Powered setup I have (Win 7 64 bit, PTMP 8.0.1, M-Audio 1814). Installing these two plugs was not smooth and appeared to fail at first. I got error messages mid install and near the end of the install but just kept clicking on choices that forced the install. In the end, a message said that the install of these plugs failed - but it did not. They work just fine with PTMP. So if you get these error messages during the install, just keep forcing the install and don't accept the option to abort the install of the McDSP plugs. It might work for you. There is no doubt that McDSP has some work to do. I have the latest PACE drivers (both 64 and 32 bit drivers installed). The only other item of note is that I have the M-Audio 64 bit beta drivers installed so the firewire works. (I still haven't tried this with my LE rig (Digi002r) as Digi has yet to release a PT update with 64 bit firewire drivers.) Hope this helps, Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
#33
Re: Win7 + HD 8.0.1
If i do a try on Win7 x64 with PT HD2 should i go with the xp or vista installers?
Any difference? Thanks a lot
PT 8.0.1cs1 HD2 Win7 x64 ... running fine with most plugs WinXP Pro SP2 ... the old cow Mobo ASUS P5WDG2 WS Pro Intel [email protected] 8GB Kingston xtreme memory |
#34
Re: Win7 + HD 8.0.1
I don't think you get a choice of Vista or XP, just Windows or Mac with McDSP plug-ins. However, if you do get a choice (for any plug-in for use with Win 7) I would choose a Vista installer.
FWIW, I'm guessing that things will go fine for you. You will likely just have to close the installer manually (using task manager) at the end of the install. Hope this helps, Greg
#35
Re: Win7 + HD 8.0.1
What does this mean? I just downloaded the latest ilok driver and installed it, but surely you can only have one hardware driver installed for a particular ilok? Can I make Windows 7 64-bit install a 32-bit driver? Might help with Cranesong I guess which some people seem to have working...
#36
Re: Win7 + HD 8.0.1
lennieh,
No, only the 64 bit driver is installed on WIn 7 x64. It is strange though as it installed in the Program Files(x86) folder (which is usually where all of the 32 bit apps install). The 64 bit apps/drivers have been showing up in the Program Files folder. I do have the 32 bit version of the PACE drivers installed on another drive. I guess I was just saying that both versions of the latest PACE drivers are solid. Greg
#37
Re: Win7 + HD 8.0.1
I have a clear choice to download a xp or vista version 32 bit. Which one did you guys use for an install on win7 x64? Best Olek Im sorry, you were right. there are only windows installers.
#38
Re: Win7 + HD 8.0.1
just in the middle of installing pro tools .... tip tip -----
#39
Re: Win7 + HD 8.0.1
after running PT8 / HD3 pcix Accel on an i7 box with XP for a few months, I just fresh-installed win7 and can report no big problems yet...all the time using the Supermicro X8SAX (the only i7 board out at the time w/ 3 pcix card-compatible slots).
the day job/family interferes w/ heavy testing, but yes THE MEMORY PROBS ARE GONE...loading lots of Omnispheres and Ivory w/out getting error messages...all while playing back about 40-ish tracks... wonder if there's in the meantime another i7 board w/ 3 contiguous slots for us pcix card guys (since no one else here seems to mention using this board)... now if I can just replace the legacy Unitors w/ midi interfaces sporting 64 bit drivers...!
kirk |
#40
Re: Win7 + HD 8.0.1
sorry for the false promise guys...there's are indeed problems w the above-described setup...
plays back 40-ish stereo tracks just fine...but Omni does not work consistently (i.e., PT freezes)... will report more but not extensively as I'm not of an age/job circumstances to do free testing...
kirk |
mac pro 1.1 for 64 bit win7/hdx | klaukholm | Pro Tools HDX & HD Native Systems (Win) | 6 | 12-11-2013 12:41 PM |
Here goes nothing - Bye Bye XP, hello Win7 | markus44uk | Windows | 17 | 10-02-2011 07:51 AM |
big BUG in PT8.03 under win7 X64 | 32768 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-05-2010 03:47 PM |
Win7? | Fullsound Recording | Pro Tools TDM Systems (Win) | 10 | 04-30-2010 09:44 AM |
GR4 PT 8.0.1 Win7 | jazzmandan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-01-2009 06:19 PM |
