Old 12-07-2004, 01:48 AM
AROOM AROOM is offline
Default NTFS vs FAT 32
i noticed my main hard drive is NTFS and my secondary music drive is fat 32. Is this a problem? should they both be the same? I read it might affect that play button staul I've been getting when I press space bar or 0 or 3 on the key pad. What does everyone else have? and any luck with the play button freezing up with 6.4
thanks
Old 12-07-2004, 01:59 AM
bb_aus bb_aus is offline
Default Re: NTFS vs FAT 32
system drive should always be NTFS
audio drive doesnt realy matter
my audio partition is FAT32 and system/data is NTFS but i havnt noticed any difference between FAT32 and NTFS on the audio drive
in theory FAT32 will run faster for audio as you can use a larger cluster size which means less disk i/o in practice it doesnt make a noticeable difference
FAT32 is also limited to 32GB (someone correct me if the figure is wrong) and has some name limitations but again they shouldnt matter
if its working just leave it how it is
Old 12-07-2004, 09:53 AM
CozmoXP CozmoXP is offline
I didn't used to have a problem with the play button but it seems to be getting worse. It is pretty bad now and is QUITE annoying when I'm trying to work. I'm using NTFS on all my drives.
AthlonXP 2700+, 1.5GB XMS DDR,A7N8X Dlx,120g 8mb Seagate System drive, 160g 8mb SATA recording drive, dual 19" CRTs and an 002r on XPSP2!
Old 12-07-2004, 09:59 AM
K.B. K.B. is offline
If you wish to use any external drives to take to a Mac (such as for a final mix on HD), you'll need the appropriate partition to be FAT32 for the Mac to be able to read it.
Old 12-08-2004, 04:52 PM
Ok pretty interesting.
I was speaking to a rep and e made me try doing a session on my system drive instead of my secondary drive to see if the play button would freeze.
Well it worked fine leaving me to believe its a problem with my music hard drive. They are both on the same wire in the computer. Can i change one to master an one to slave to see if this helps. or the system has to be the master?
i have 2 wetern digital 120 gig drives.7200 .. the newer one seams to staul the play button.
They are both DMA enabled. and all the tweaks were done as recommended. Still staulling since 6.4 download on the D drive. any other suggestions?
Old 12-08-2004, 09:19 PM
system drive should always be the primary master
i find it best for the audio drive to be the secondary master (or use SATA) and then put CD/DVD drives as slaves
Old 12-08-2004, 10:30 PM
Matt Whritenour Matt Whritenour is offline
it's more around the range of 113GB
www.klarityrecordingstudios.com
Old 12-08-2004, 10:55 PM
Keep guessing, then get the facts:
http://support.microsoft.com/default...b;en-us;314463
Quad 2.5 G5, 4.5G RAM
Old 12-08-2004, 11:34 PM
JFreak's Avatar
JFreak JFreak is offline
macs can read NTFS, also, windows can read HFS (after a 3rd party app installation).
Janne
Old 12-09-2004, 10:33 AM
That isn't entirely true. That is an artificial limit placed on the max size of a new fat32 partition in XP. If you have another way to create the partition you can make one bigger than 32 gigs. They added that limit because fat32 becomes rather inefficient at sizes bigger than 32 gigs. FAT32 is dead anyway. There's no real reason to use it on fixed disks any more, unless you're still dual booting win9x or something.
Last time I did some performance tests of NTFS vs FAT32, NTFS had a read speed that was significantly higher than FAT32.
No security = no thanks.
Fat 32 to NTFS finalcut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-13-2005 08:22 PM
PT and NTFS niespodj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-04-2003 01:28 PM
FAT 32 or NTFS? motion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2003 08:37 AM
FAT 32 or NTFS .... and gwattaloopy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-14-2003 07:11 AM
Fat 32 vs NTFS Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-25-2002 01:51 PM
