Old 04-06-2011, 03:05 AM
PUMASALAD PUMASALAD is offline
Default I/O from Focusrite Liquid Saffire 56 in PT9
I've just upgraded to PT9 using an iMac with a Liquid Saffire 56 as the hardware. The chain is Saffire 56 > HARD DRIVE > iMac. If I start a new session all the digital I/O are fine (DAW13 > ADAT 1 etc). When I try to use a session previously set up on my old PT (LE 7 using PT hard ware) and hit DEFAULT for the I/O it goes weird! I get two lots of ADAT 1-2 and ADAT 5-6. They are routed to different places: one set of 1-2 goes to 9-10 and the pther goes to Optical 11-12. Manually putting them in the correct places and renaming the 'spare' ones doesn't seem to help e.g. if I call the 'spare' ADAT 1-2 "BLANK" when I try to put ADAT 1 as an O/P I get BLANK L-R as an O/P. Any ideas? Focusrite have been helpful, but are at a loss.
Old 04-08-2011, 02:29 AM
Default Re: I/O from Focusrite Liquid Saffire 56 in PT9
No-one out there got any ideas at all!!!!!
Old 04-08-2011, 08:31 AM
danander11 danander11 is offline
I can't speak to your exact issue, but a few folks are having I/O routing and renaming issues. There are a few threads on it.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 04-08-2011, 06:02 PM
appledude appledude is offline
Open up a session that is correct and export the settings. Trying unchecking the box that says "Sessions overwrite current I/O Setup when opened". Then close window and save the session. Then open the old sessions and see if it looks correct.
Imac Pro 27" 10-core with a LG 4K for a second screen
OS 10.14.4
Pro Tools 2019.6
UAD Apollo X8P With an extra 8 channel ADAT using
a Focusrite Liquid Saffire 56
UAD Twin duo
UAD TB3 Octo Satelite
Focal Twin Be monitors
samsung T5 and Gdrive
Old 04-10-2011, 07:37 AM
Thanks for the responses. Yes, I've sort of sorted it, but it's a bit illogical. I've simply deleted the paths which were duplicated and manually put the o/ps where they should be and that's fine. I've done the same with the i/ps, but it's a bit illogical. It defaults to ADAT 1-2 to DAW9-10 which ought to be wrong but works! And, yes I've unchecked the sessions overwrite and saved the settings and it's been behaving itself. What I'm getting now are a little of little clicks (random and not on all channels). All the clocking seems correct and everthing is showing "locked". Why is nothing ever simple!!
Old 04-11-2011, 08:11 AM
You have not told us much about your system. Are you using the ADAT into the Saffire? Are you using the saffire under a Aggregate device or by itself? Are you using mixcontrol 2.4B with the latest firmware update and RTAS mixcontrol 1.0b1?
OS 10.14.4
Pro Tools 2019.6
UAD Twin duo
Old 04-11-2011, 03:17 PM
smbirddog smbirddog is offline
Under Setup -> Playback Engine is your current engine (top drop down) set to Saffire?
Mac Pro OSX 10.6.3
Pro Tools 9
Liquid Saffire 56
Old 04-14-2011, 11:31 AM
Thanks again. To answer points:-
Yes it's reading the Saffire
The Saffire is clocked from an external clock with ADAT in for ISA828 and Octo-pre (both from same external clock.
Mixcontrol is the latest version (we've just unearthed a bug which Focusrite are going to fix in the next release (saved setting won't open under the FILE menu).
Not using the RTAS Mix control - mabe I should!
Don't know if the clicks have disappeared because I've had a hard disk problem and had to revert to my old ProTools set-up. My new LACIE Quadra 1TB will load the session, but PT won't go into Play mode. My old Macally HD works fine. I've just discovered that if I try to use an old PT7 session in PT9 it won't let me use digital O/Ps 9,10,11,12 etc as singles only as stereo pairs. Need to get my head round that!
Focusrite Liquid Saffire 56 YYR123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-25-2012 05:13 AM
Focusrite Liquid Saffire 56 muzicmaken Pro Tools 10 0 03-31-2012 09:17 PM
Focusrite Liquid Saffire 56 YYR123 Pro Tools TDM Systems (Win) 7 11-16-2011 11:57 AM
Focusrite Liquid Saffire 56 YYR123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2011 11:31 AM
Focusrite Liquid Saffire 56 and PT 9 ? trock Pro Tools 9 5 09-19-2011 04:27 PM
