Old 01-25-2018, 10:05 AM
Greg C Greg C is offline
Default SC48 crashing into Backup mode
Hi guys. I have a SC48 probably 6 years old that's been relatively flawless. Lately it started crashing into backup mode, usually after a cold boot after it's been stored. Once it's recovered from 1 or 2 crashes, it stable. Before I open it up and start reseating everything, I want to get some opinions on potential common causes. Might it be:
1 - ribbon cables & connectors?
2 - failing boot drive?
3 - corrupt show file? (I usually load the same start file from 2 years ago)
3 - [your answer here]
I haven't had the board open since it was new & I installed the IO16 in it. If I go digging into it, I think I'll replace the boot drive with an SSD.
Thanks for any suggestions.
Cameron Pro Audio
Exclusively at the Miners Foundry
Old 01-25-2018, 10:47 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: SC48 crashing into Backup mode
Your list looks pretty spot on, I would suggest giving support a call though.
#3 would be very easy to check if you just clear console,
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 01-28-2018, 03:55 AM
brinnbacka brinnbacka is offline
From my similar experiences with a Profile system, I would recommend checking and cleaning the RAM first. In my case it didn't help as the motherboard was dying. So that'd be my second guess. Never saw a corrupt show file do this kind of thing.
Old 01-29-2018, 08:12 AM
emluper emluper is offline
When's the last time you changed the BIOS battery? I found out about this the hard way. Entire service brought down by a $2 battery.
Old 02-01-2018, 09:13 AM
Well, the clock hasn't lost time. So the battery is probably ok. But I'll replace it when I dig into it.
Cameron Pro Audio
Old 02-01-2018, 09:16 AM
Thanks Ryan. I'll call support for sure.
Cameron Pro Audio
Old 02-01-2018, 10:57 AM
Are you getting the Windows "blue screen of death" at all? If that happens intermittently but everything is fine once it fully boots, then it's definitely the BIOS battery. Good luck, hope that's all that it is.
Old 02-01-2018, 03:14 PM
No BSoD - yet...
Cameron Pro Audio
Old 03-08-2018, 09:09 AM
Just wanted to follow up. After reseating just about everything I could get my hands on short of completely disassembling the DSP board sandwich, I haven't had any further crashes.
Greg
Cameron Pro Audio
Old 08-22-2018, 11:56 PM
Tim McCullcoh Tim McCullcoh is offline
Hi Greg-
There should have been an error message prior to the recovery prompt message; the one we had was "critical system DSP error". If that sounds familiar the likely solution is to remove the PCI bus extension card cage (HUB 48, and TDM mix engine cards 0 and 1), remove each card and gently clean the fingers with your choice of appropriate chemistry. The TDM jumper between the mix engine cards is one source of DSP errors and unmating and remating it has been sufficient. Put it all back together and boot it up. Common error in reassembly is to mis-plug a CAN bus connector (been there, didn't want the shirt).
Venue support can provide you the service manual chapter that walks you through disassembly to get down to the PCI extender.
You'll spend more time taking the console apart than fixing the problem.
If you've already fixed the crash problem please fill us in!
Tim Mc
SC48 troubleshooting. Will not boot beyond Standby Mode. Sidhu VENUE Live Sound Systems 2 09-21-2015 08:29 AM
Venue Profile system crashing into backup mode brinnbacka VENUE Live Sound Systems 4 06-18-2014 03:41 PM
SC48 in 64 channel mode (not enough layers) question Jamie_aep VENUE Live Sound Systems 4 10-15-2012 08:04 PM
SC48 Test (Vegas) Mode? XxAExX VENUE Live Sound Systems 2 07-24-2011 07:42 PM
Stereo Groups, Expert Mode, SC48 Limelight VENUE Live Sound Systems 1 10-14-2010 05:06 AM
